ML10 Apron Wheel
ML10 Apron Wheel
Home › Forums › Beginners questions › ML10 Apron Wheel
  • #358082
    Paul Ainsworth
      @paulainsworth93685
      Using the search I came up with the answer to part of my question about this modification, 5/16"BSF thread.
      Now the other half, will an apron wheel off either an ML7 or Super7 clear the cross slide?
      Have you done the mod? What did you use?
      #9223
      Paul Ainsworth
        @paulainsworth93685
        #358096
        Robbo
          @robbo
          Paul
          The apron handwheel on an ML7, and the older Super 7, is 3.5 inches diameter. That should tell you if it will swing clear of the cross slide.
          #358101
          Paul Ainsworth
            @paulainsworth93685
            Cheers Robbi, it'll fit with room to spare.
            #358108
            Jim Guthrie
              @jimguthrie82658
              Don't forget that the apron handle on the ML10 doubles as a thread dial indicator and you might have to make alternative arrangements if you need this facility.
              Jim.
              #358141
              Redsetter
                @redsetter
                I haven't found the lack of an apron hand wheel on the ML10 to be a big problem, and I'm not sure that the ML7 item will fit without modification. What the basic ML10 does lack is a graduated dial on the lead screw.
                Of course, if you've got a lathe, you can always make these things!
                #358144
                Paul Ainsworth
                  @paulainsworth93685
                  Posted by Jim Guthrie on 16/06/2018 20:58:14:
                  Jim.
                  Indicator dial is behind lock nut so hopefully should be able to keep it.
                  #358145
                  Paul Ainsworth
                    @paulainsworth93685
                    Posted by Redsetter on 17/06/2018 08:43:50:
                    That's the next job
                    #358147
                    Clive Hartland
                      @clivehartland94829
                      The ML10 graduated Leadscrew dial is a Mod. for ML10. I fitted mine some time back.
                      I am sure it is available? You have to cut the lead screw and fit a clutch at the left hand end.
                      #358148
                      Paul Ainsworth
                        @paulainsworth93685
                        Dog clutch already fitted
                        #358664
                        Paul Ainsworth
                          @paulainsworth93685
                          That's one done, a bit of fettling to do before I fit the leadscrew wheel.
