methylated spirits
methylated spirits
Home › Forums › Locomotives › methylated spirits
  • #1370
    UJ Newton
      @ujnewton33659
      #178733
      UJ Newton
        @ujnewton33659
        Want to soft solder a meths burner for a very small boiler but am not sure which soft solder to use..Spent long enough on internet to write a thesis on meths !but still dont know what temperature it burns at!
        #178735
          @mike89748
          Try www. stirlingengineforum.com/viewtopic.php?f=1&t=935 . They give the temperature of a meths flame as 1100 degrees C.
          #178738
          UJ Newton
            @ujnewton33659
            Crikey,thats warm ..think I might just buy a gas burner ..Thanks Mike
            #178739
            martin perman 1
              @martinperman1
              I repair meths stoves for boiling water in kettles and use soft solder, your burner is via a wick I assume so the container shouldnt get that hot.
              Martin P
              #178745
              UJ Newton
                @ujnewton33659
                Ok Thanks Martin..whichsolder do you use?
                #178749
                martin perman 1
                  @martinperman1
                  Lead sticks and bakers fluid, no idea of grade as it was acquired from my father in laws tools which he left me, I make fuel tanks for my petrol engines without any problems.
                  Martin P
                  #178752
                    Flame temperature isn't a good guide to it's actual heating ability. Bear in mind you can pour whisky or brandy on ice cream and burn it without the ice cream melting (why would ANYONE want to burn such things?)
                    You need a blowpipe to get a meths flame intense enough for even silver soldering the tiniest of items.
                    UJ Newton
                      @ujnewton33659
                      Ha ha..I burn them..Being in catering I get paid to..Utterley ridiculous!
                      Glad about meths though..I m sure I cam build burner and tank lot cheaper than buying a gas one..Fumes arent the same either
                      #178768
                        Just read that properly – this is for the burner NOT the boiler.
                        I'd suggest using Comsol (286 degrees C) but bear in mind that the evaporating meths will cool the burner and once its all evaporated, there's nothing left to burn.
                        nigel jones 5
                          @nigeljones5
                          Come on Neil…….don't you put poison darts into a blow pipe……
                          #178771
                          UJ Newton
                            @ujnewton33659
                            #178779
                            JohnF
                              @johnf59703
                              Hi UJH i would use tin and resin flux or the self cleaning flux used by plumbers, this is slightly acidic so you need to wash of with water when finished, same with killed spirits. You could equally use tin mans solder 60/40 lead/tin but tin flows better and makes a stronger thinner joint. Tin you can buy the "lead free" solder at the plumbers merchant which is near enough pure tin.
                            Home › Forums › Locomotives › Topics
