Measuring 3 1/2″ gauge
Home Forums Beginners questions Measuring 3 1/2″ gauge
  • #158933
    Eric Cox
      @ericcox50497
      When measuring the 3 1/2 " across a pair of wheels, where should the dimension fall. ie, to the centre of the wheels or to the outside of the flanges.
      #7248
      Eric Cox
        @ericcox50497
        #158935
        Weary
          @weary
          The flat side of the rail should lie just inside point P on this drawing.
          The drawing gives enough info' to sort out your gauge dimensions.
          Phil
          #158961
          julian atkins
            @julianatkins58923
            hi eric,
            the right hand position of 'P' on phil's excellent link determines the gauge. the root ie radius on the flange to tread should be inside the 'gauge dimension' of 3.5"g. however take phil's excellent link with a bit of caution as very few 3.5"g designs show either an adequate root radius or a taper on the flange, or for that matter a taper on the treads.
            in theory the root radius should start at the gauge dimension. with the old fashioned steel strip rail this was rather essential otherwise you would be tight on the gauge. with vignoles section steel rail on most club tracks these days, which have a curved edge to the railhead, you should be able to push the wheelsets over sideways 1/16" if not more across the rails.
            cheers,
            julian
            #158966
            Gary Wooding
              @garywooding25363
              Just to show what an ignoramus I am, what is dimension "B"?
              Gary
              #158969
              Weary
                @weary
                B = 'Back to back'.
                Happy measuring!
                Phil
                #158970
                Eric Cox
                  @ericcox50497
                  "B" is the distance between the backs of the wheels. As a fraction it's 3 9/32"
                  #159039
                    With my modest experience of wheel making, I have used the back to back dimension as my reference, putting shoulders on the axles.
                    I've done this for both 3 1/2" (loco) and 5" gauge (driving truck) and to my surprise they both work!
                    Gary Wooding
                      @garywooding25363
                      Got it. Thank you.
