Materials Question
Materials Question
Home Forums General Questions Materials Question
  • #348912
    Johnboy25
      @johnboy25
      Hi… I’m trying to dedemine the black composite material used for good quality handles for kitchen knives. I haven’t found any thing on t’internet as yet. While we’re on the subject of materials – are there any suppliers of the old style Ebonite out there anymore? John
      #25924
      Johnboy25
        @johnboy25
        Black composite
        #348925
        richardandtracy
          @richardandtracy
          Good quality ebonite is not all that easy to get hold of these days. Most of it is filled with chalk or other bulk fillers. If you want good stuff, look for pen blanks, swallow hard, and look again because it's very expensive. There is a German Company that I have not used, but a number of pen makers I know of have used. They are here: **LINK**
          Pipe makers also use it. There are a number of suppliers from India on E-bay who sell reasonable quality material. I have no idea how good Russian or Ukrainian material is.
          For fancy coloured, good quality ebonite see American Art Plastics (seem off line at the moment) as they do hard rubber & new celluloid.
          Richard.
          #348932
          Speedy Builder5
            @speedybuilder5
            Small bits from old pianos.
            #348934
            pgk pgk
              @pgkpgk17461
              ..would it be worth experimenting with black pigments mixed into epoxy and cast roiughy to shape for finish polishing?
              pgk
              #348936
              David Standing 1
                @davidstanding1
                Are you talking the solid black stuff used on Sabatier and the like, or the stuff that is layered a bit like a laminate?
                The latter is Micarta
                #348937
                John Haine
                  @johnhaine32865
                  Corian?
                  #348942
                  richardandtracy
                    @richardandtracy
                    Acrylic/polyester turning blanks from somewhere like Axminster look pretty good as laminates on either side of a decent tang. Axminster do 50mm dia blanks in horn, ivory & tortoiseshell alternative materials. They turn very nicely with carbide inserts – **LINK**
                    Richard.
                    #348956
                    Vic
                      @vic
                      Posted by David Standing 1 on 05/04/2018 15:16:50:
                      We have a 30 year old Sabatier bread knife on which both sides of the handle have cracked. There are no visible signs of any layers so I have no idea what the material is. I was under the impression that Micarta was a fabric impregnated with resin?
                      I have some off cuts of a laboratory bench top material called Trespa which is black under the surface treatment. I wonder if it could be something like that?
                      Johnboy25
                        @johnboy25
                        Thanks all for your replies – much appreciated. I’ll check them all out.thumbs up
                        #348969
                          GP Agencies do quiet a few materials that can be used for handles, check the link for JB Supply at the bottom, they do knife scales and full sheets (nothing to do with me)
                          #348989
                          David Standing 1
                            @davidstanding1
                            It is almost impossible to find out what the black material used for quality kitchen knife handles is, but, having done some research, I am convinced it may be bakelite.
                            It should not be confused with newer handles, which are POM (Polyoxymethylene, or Acetal).
                            #348990
                            JohnF
                              @johnf59703
                              Johnboy25, Ebonite is used extensively in the gun trade for stock extensions, butt plates etc so they your local gun shop. If you don't have any luck PM me and I will try to help
                              Mike Poole
                                @mikepoole82104
                                My father spent a few years in Ceylon(Sri Lanka) and one of his colleagues wanted some ebony to carve, the locals told him which tree it was but every time he cut the tree it was white, the mystery was solved when he found a cut tree and realised only the heartwood was black. He would be in trouble now as the ebony tree is protected in Sri Lanka.
