Mardrive component Misplaced motor component
Home Forums Workshop Tools and Tooling Mardrive component Misplaced motor component
  • #212459
    martin baker
      @martinbaker81996
      img_1285.jpgFour years ago I dismantled my Pultra lathe whilst moving workshops. Only now have I been able to re-assemble the unit but I have come up against problems due to my stupidity ant not noting down where certain parts came from. I have attached an image of a part that I assumed came from inside the clutch cone of the motor but if it is put there the clutch cone cane be returned to its original position. I am hoping in anticipation that someone has had experience of Mardrive units and could advise. Many thanks.
      Edited By martin baker on 15/11/2015 17:26:25
      martin baker
        @martinbaker81996
        #212462
          Martin,
          Sorry to say, your 'image' is missing, and your album only contains two Myford pictures.
          martin baker
            @martinbaker81996
            Sorry having problems with adding the image but have done it now I think. Martin.
            #212467
              Yes; Image is there now, Martin
              Unfortunately, I don't immediately recognise it.
              … I may be back [but don't hold your breath !]
              Edit: this page has a cross-sectional drawing, taken from the Patent, but shows nothing that I recognise as your component. [Both of mine are incomplete, and presently inaccessible]
              Edited By Michael Gilligan on 15/11/2015 17:50:11
              #212468
              Phil P
                @philp
                I does not look like part of a Mardrive to me, I have the type that is built into a lathe cabinet and there is nothing like that part in it.
                Phil
                #212470
                  It looks like the sprung roller of a limit switch to me?
                    I don't think it will help, but here & here & here are the early Patents
                    Note the somewhat surprising Applicant.
                    Edited By Michael Gilligan on 15/11/2015 22:08:11
                    Edited By Michael Gilligan on 15/11/2015 22:10:09
                    #212532
                    Arthur Sixsmith
                      @arthursixsmith43623
                      We used this type of clutch/motor on sewing machines. The spring and roller whent down the motor shaft to keep the flywheel and pulley apart. Hope this helps Arthur
                      #212534
                        Arthur,
                        So … is it item 'd' on the sectional drawing?
                        I felt sure that mine just had a 'button' … but the roller would make sense.
                        Thanks for joining us.
                        MichaelG
                        #212537
                        Phil P
                          @philp
                          I can tell you for sure item D is just a short pushrod with a spring connected to the back end of it.
                          In normal operation the clutch friction ring is held apart by this spring so it does not drive, when the pedal is pressed it pushes the cone pulley inwards and contacts the friction ring thus taking up drive until the pedal is released.
                          I reckon the part in the photo is from somewhere/something else.
                          Not sure why the patent applicants name is surprising, mine has the 'Marine Engineering Co' name on the main motor plate. That is where the name "Mar" drive comes from isn't it ?
                          Phil
                          #212538
                            Posted by Phil P on 16/11/2015 00:00:54:
                            Phil
                            Yes, Phil … It is obvious when you already know [which I did], or if you happen to have an original motor with that nameplate [one of mine does, the other does not].
                            But anyone presuming that the famous Pultra MarDrive unit might be the intellectual property of Pultra would probably struggle to find the Patents.
                            I was just trying to help, by putting a little more information where people might easily find it.
                            Phil P
                              @philp
                              From the way you worded it, it sounded like "you" were surprised by the patent application name. You could have explained it to everyone if you had wanted to.
                              Perhaps I had better mind my own business in future posts of yours if I have spoken out of turn.
                              Phil
                              #212557
                                Posted by Phil P on 16/11/2015 07:28:15:
                                Phil
                                Phil,
                                No, I don't think you have spoken out of turn … but, equally, I didn't think it was worth 'explaining it'
                                There has been enough nonsense on this forum in recent days; let's just all work together.
                                martin baker
                                  @martinbaker81996
                                  Thanks to you all.
                                  #212702
                                  Ajohnw
                                    @ajohnw51620
                                    Not sure but this page shows some copies of drawing from the patent but near the top is a "photo" of a cord passing over a pulley to operate the clutch. It's not clear but it looks like something like your part might be connected to the cord.
                                      Posted by John W1 on 16/11/2015 23:18:32:
                                      … a "photo" of a cord passing over a pulley to operate the clutch. It's not clear but it looks like something like your part might be connected to the cord.
                                      John,
                                      For info. … That 'cord' was a chain [lightweight flat links]
                                      There is a very useful little video, here, showing a bench-mount MarDrive unit in very original-looking condition.
                                      clockwork1957
                                        @clockwork1957
                                        Hi Martin,
                                        Do you still have the Pultra and Mardrive cabinet.
                                        I’ve just purchased one and am reaching out for any links to a parts list for the 1590 and the Mardrive motor drive.
                                        Thanking you in anticipation.
