manual to cnc
manual to cnc
  • This topic has 12 replies, 7 voices, and was last updated 15 May 2018 at 18:55 by peter ravenscroft.
  • #353998
    peter ravenscroft
      @peterravenscroft57700
      hi can anyone help me i have bought an aduino and i am trying to load the program grbl as recomended by the article but all i get is copy error message
      the ardiino will load other programs no problem i am wondering if anyone else has had a problem trying to load grbl
      regards
      peter
      #15183
      peter ravenscroft
        arduino not loading program
        #354004
          Hello, Peter
          Is it a 'genuine' arduino or one of the many 'clones' ?
          One of the variations seems to be the use of a different [presumably a little cheaper] USB chip.
          … You may need to install the appropriate driver. … CH340G instead of FTDI
          Edit: But it does seem odd that you can load other programs dont know
          Edited By Michael Gilligan on 14/05/2018 15:49:26
          #354017
          peter ravenscroft
            i already have the driver i do not think it is the driver as it will load other programs i have used several arduino units the last on being a dividing head which works ok
            thanks for your help
            regards
            peter
            #354019
              Sorry, Peter … I'm out of ideas
              Over to the experts >>>
              Muzzer
                @muzzer
                You might be better off asking on the GRBL or Arduino etc forums. Sounds like a specific issue that somebody may have come up against before or at least understand the problem.
                Murray
                #354031
                John Haine
                  @johnhaine32865
                  Just a thought – if you are converting a manual m/c tool to cnc, it might help to reduce the number of variables if you went for Mach 3, which has a wide user community?
                  #354043
                    It seems grbl has a slightly unusual install mechanism : if I read it correctly, the source files are loaded into a project folder in the usual way from zip, but are then compiled via grblupload in the examples folder, not directly.
                    Are you following the instructions here? Judging by the comments it is important to follow the instructions exactly. Which model Arduino and what's the error message?
                    I'll try it myself in a moment and see how I get on!
                    #354048
                      Posted by SillyOldDuffer on 14/05/2018 20:51:56:
                      Not very well! I've hit a different problem entirely and need to switch to a different laptop. Why is nothing ever easy? Perhaps tomorrow…
                      #354053
                      Raglan Littlejohn
                        @raglanlittlejohn
                        I loaded grbl onto an Arduino a couple of years ago. I used the instructions from NYCNC https://www.youtube.com/watch?v=1ioctbN9JV8.
                        #354055
                        Another JohnS
                          @anotherjohns
                          Posted by John Haine on 14/05/2018 19:35:12:
                          John;
                          This is my impressions of following this for a while.
                          I'd expect GRBL to have 10x to 100x the user community of Mach 3.
                          You can run it on those 3D printer boards, (it does not do extruders, unless it's been updated) so if you want a small CNC machine, it's ideal.
                          I gave away my Unimat CNC machine, and suggested that the user try GRBL for it, rather than go for high priced hardware, required for Mach 3 and LinuxCNC. (what's a 3D printer board worth? A pint of beer? less, if you get it from a defunct printer, I'd expect)
                          JohnS.
                          #354060
                            Posted by SillyOldDuffer on 14/05/2018 21:28:55:
                            Or perhaps tonight.
                            Took me no more than 5 minutes to download the zip from git to my Windows 10 laptop and install it as an Arduino library following the instructions I linked to above and to flash it on to a real Arduino Uno R3. I have Arduino IDE v1.8.4.
                            So it does work. I had trouble doing the same thing earlier with Ubuntu because the zip package fails validation as a library and breaks the install. (This is a known Issue, and you don't get as far as bening allowed to compile anything, so probably not Peter's problem.)
                            Any other clues Peter?
                            peter ravenscroft
                              hello all
                              many thanks for your advice i should have taken silly old duffer's advice you have to read it very carefully i got there eventualy
                              it is very arkward to say the least will let you know how i got on
                              regards
                              peter
