I have a set of original Stuart Turner (not the current Stuart Models) castings for the reversing gear for the #1 engine. The eccentric rods are supplied as mallable iron castings and they are both warped to the extent that they won't clean up to the desired 5/32" thickness as required, as there is minimum machining allowance on them. My question for any one who has worked with mallable iron is, are they ductile enough to hammer strait or are they going to snap like normal cast iron would.
These two appear to be identical castings to the one I have just finished machining for my #1 (castings of the the same vintage). It was only slightly warped and machined beautifully, much like mild steel except that the chips came off as little chunks, much like cast iron or hard brass.
