Loseby’s Isochronal Spring
Home › Forums › Clocks and Scientific Instruments › Loseby’s Isochronal Spring
  • #653409
    david bennett 8
      @davidbennett8
      Has anyone noticed this? I came across it in my pdf copy of Grimthorpe's Clocks Watches and Bells on pages 63/4. There is a very brief description. It seems to be a very simple single loop of spring wire loosely embracing the pendulum rod so that over-impulsing would cause the rod to stretch the loop. This device was exhibited in 1851 and at first the Astromer Royal said it worked. Then Grimthorpe intervened on the grounds that escapement errors had the opposite effect. The AR did some more experiments, then dismissed the spring.
      Now that the trend is towards removing the escapement and it's errors, is it time to re-visit this? Does anyone have any detail of it's construction? If it is any use it could easily be retro-fitted to any pendulum.
      dave8
      #4026
      david bennett 8
        @davidbennett8
        #653414
          Thanks for the reference yes
          I felt sure that I had a PDF on the iPad, in GoodReader … but couldn’t find it crying 2
          Downloading it again revealed the file name and all is now well.
          John Haine
            @johnhaine32865
            This kind of arrangement has been invented more than once to correct for circular deviation.
            #653428
            david bennett 8
              @davidbennett8
              Posted by John Haine on 23/07/2023 18:03:26:
              John, after much unsuccessful searching, can I ask if you have any references?
              dave8
              #653441
                Brief mention of Loseby’s device here: **LINK**
                Loseby Reasearch
                david bennett 8
                  @davidbennett8
                  Thanks Michael.Yes, I had seen that sad story. The British Museum suggested a couple of books. Nothing in Brittans, I dont have access to the Loomes clockmakers list.
                  dave8
                  #653448
                    david bennett 8
                      @davidbennett8
                      Michael, thanks. The link didn't work at first until I re-entered the search with inverted commas. I take it it's the engraving of a mercury compensated pendulum with what could be the spring?
                      dave8
                      #653465
                        Indeed, Dave yes
                        Sorry … I hadn’t noticed the ascii error …
                        david bennett 8
                          @davidbennett8
                          Thats ok. I have found it with explanation on internet archive. Its " The practical mechanics journal" vol 5 dated 1853. The explanation is not much more than can be guessed at from your pic.
                          dave8
                          Edited By david bennett 8 on 24/07/2023 04:34:18
                          #653518
                          david bennett 8
                            @davidbennett8
                            Posted by david bennett 8 on 24/07/2023 04:33:52:
                            ps – page31
                            dave8
                            #653524
                            John Haine
                              @johnhaine32865
                              David,any chance you could post an image of the relevant page or a direct link please?
                              #653549
                              david bennett 8
                                @davidbennett8
                                John, willl try -the file is too large
                                dave8
                                #653555
                                david bennett 8
                                  @davidbennett8
                                  https://books.google.co.uk/books?id=B9pQAAAAYAAJ
                                  Hi John, see if this works
                                  dave8
                                  #653639
                                  david bennett 8
                                    @davidbennett8
                                    https://books.google.co.uk/books?id=nDxWAAAAcAAJ
                                    John, have just found this better account of Loseby's compensator
                                    dave8
                                    Edited By david bennett 8 on 25/07/2023 14:26:30
                                    #653641
                                      Well done, Sir
                                      … tucked away quietly after his masterly ‘secondary compensation’ of the Chronometer Balance
                                      Edited By Michael Gilligan on 25/07/2023 14:25:43
                                      #653689
                                      John Haine
                                        @johnhaine32865
                                        Thanks Michael and Dave. Similar in principle to methods proposed by others except Loseby was first and certified by Airy no less! I will try to dig out the other references I've seen.
                                        #653773
                                        John Haine
                                          @johnhaine32865
                                          The other key reference on this is by Bush and Jackson "Correction of spherical error of a pendulum" in
                                          Journal of the Franklin Institute
                                          Volume 252, Issue 6, December 1951, Pages 463-467
                                          alas only available if you pay or have institutional access. Vannevar Bush was an eminent US science maven in WW2 and after who played a major role in things like early computers etc. Also interested in clocks and there are a couple of articles in Scientific American describing their experiments dating from the early 1960s. The article above has a reference to Loseby but he only had the rather negative Grimthorpe reference and hadn't seen the Practical Mechanics stuff and the test report by Airy. The scheme used a tension spring pulling downward on a point on the pendulum, the other end being held vertically below the point of suspension. As the pendulum swings the spring is slightly stretched and the geometry can be designed to provide an additional restoring force proportional to the cube of the angle that can cancel the cubic term of the sinusoidal restoring force. In practice they used a cantilever leaf spring at right angles to the pendulum with a thin wire connecting it to the pendulum rod. Good results are reported, I haven't compared them with Airy's measurement yet.
                                          As far as I can see Loseby's spring creates the cubic dependency through its shape and from my brief look at the description he doesn't say what this has to be mathematically. By contrast Bush only assumes that the spring is linear (a good approximation for small extensions) and the cubic term comes from the geometry.
                                          #654067
                                          John Haine
                                            @johnhaine32865
                                            Michael was asking for more details of my claim of other mentions of a similar technique.
                                            • Loseby's approach actually only applies the correcting force over a small part of the arc on one side.
                                            • Bush/Jackson aim to exactly correct for the cubic terms at least for small deflections.
                                            • The Bulle clock included a coil spring arranged in a very similar way to Bush's to keep period constant as battery voltage declined, in the early 20th century.
                                            • David Robertson described the theory of the Bush type compensator in 1929 in one of his classic HJ articles.
                                            • IIRC Peter Hastings described a scheme a bit like Loseby's in HJ a few years ago.
                                            #654070
                                              Posted by John Haine on 28/07/2023 08:51:47:
                                              dont know really ? … I thought it was dave8
                                              John Haine
                                                @johnhaine32865
                                                Oops! Apologies both.
                                                #654075
                                                  No problem, John
                                                  david bennett 8
                                                    @davidbennett8
                                                    Thanks John. I must note that your first point is entirely in line with Loseby's aim of his correcting force "to only act through that part of the arc in which it was required". Are there any quantative results on the performance of the other attempts you mention? ( I am not expecting results on the basis of a 4:1 change of driving force as in Airy's tests.)
                                                    dave8
                                                    #654096
                                                    John Haine
                                                      @johnhaine32865
                                                      Yes, Bush and Jackson report test results. I'll post them later.
