Locomotive boiler wrap
Home › Forums › General Questions › Locomotive boiler wrap
  • #567740
    Michael Callaghan
      @michaelcallaghan68621
      Hi, what is the best way to mark out locomotive boiler wrap. With the price of even thin brass sheet now at very high prices I need to know the best way to make out the boiler wrap so I get the holes etc in the right places. I don’t think using paper would work as it tends not to keep a good shape. Thanks
      #28402
      Michael Callaghan
        #567748
        Clive Brown 1
          @clivebrown1
          I've used good quality thin card, obtainable from craft shops. Plasticard styrene sheet is also useful. Pieces of either can be stuck together with Sellotape and held around the boiler with string or elastic bands.
          #567757
          Michael Callaghan
            Good idea Clive. Thanks
            #567769
            Baz
              @baz89810
              Empty cereal boxes are useful for templates and are basically free!
              #567773
              Speedy Builder5
                @speedybuilder5
                If you use thin Clear celluloid , you can see what is happening underneath !
                #567776
                Michael Callaghan
                  All good ideas, I just found that the Amazon small parts envelope works very well. However I have a second question. I have lots of .9mm sheet aluminium, will that be ok to use. Thanks again
                  #567816
                  Chris Gunn
                    @chrisgunn36534
                    Michael, plus 1 for plasticard templates.
                    I would not use aluminium, as you will have a job to get the paint to stick.
                    Steel would be my choice of material.
                    Chris Gunn
                    #567818
                    Michael Callaghan
                      Hi, I am ok with getting paint to stick to aluminium there are a few very good etch primers to aluminium these days.
                      #567826
                      Baz
                        @baz89810
                        Michael if you can get paint to stick to ally I would go for it, especially if you already have plenty of it.
                        #567837
                        duncan webster 1
                          @duncanwebster1
                          Isn't ally more likely to get dents? Don't forget to allow for the cladding when making your templates. I think cork sheet is as good as anything.
                          #567855
                          Michael Callaghan
                            Hi Baz, I have made a few items with aluminium over the years and found that with all things to do with paint, good prep and good materials are the way to go. DUncan I have used fire blanket for the cladding and that’s in place. Ally dents no more or less then thin brass. I would like to use brass to be honest, but I have sheets of aluminium doing nothing.
