Lathe reviews?
Lathe reviews?
Home › Forums › Beginners questions › Lathe reviews?
  • #104536
    Graham Rounce
      @grahamrounce14492
      I know I can hunt around, but are there any sites that deal with reviews of metalworking lathes?
      Something like this
      http://www.ukworkshop.co.uk/forums/buying-advice-tool-reviews.html
      only for metalwork?
      Thanks again,
      #6455
      Graham Rounce
        @grahamrounce14492
        #104546
        David Littlewood
          @davidlittlewood51847
          Graham,
          Have a look at **LINK**
          Should cover most machines.
          David
          #104548
          Graham Rounce
            @grahamrounce14492
            Hi David, and thanks – that’s a fantastic resource. But I was thinking more of user reviews (of current machines)?
            #104616
            Derek Drover
              @derekdrover32802
              Best thing.. if you have a lathe in particular you want info on from actual users, look at previous threads or post the question.
              #104617
              chris j
                @chrisj
                Posted by David Littlewood on 24/11/2012 19:18:34:
                Graham,
                David
                No Warco lathes on that site (that I could find) sadly.
                #104618
                Graham Rounce
                  @grahamrounce14492
                  Hi – Ok! Anyone got any experience of the Warco Super Mini to pass on?
                  And PS, just to show off my ignorance, I think ‘Maximum swing’ (180mm) is the max diameter workpiece it will turn, but what is ‘Swing over cross slide’ (100mm)? Is it the maximum cuttable diameter?
                  #104623
                  graham howe
                    @grahamhowe83128
                    Hi, I can offer a review of my BH600G lathe from Warco which was also reviewed bu Anthony Mount in the ME 2003/4.
                    http://www.homepages.mcb.net/howe/bh600%20article.htm
                    Graham
                    #104628
                    KWIL
                      @kwil
                      Graham, your surmise is correct., obviously the cross slide height limits the maximum diameter of anything projecting towards the tailstock which actually passes over the cross slide. If it does not need to pass over then you can turn, say a wheel or flywheel up to the maximum swing.
                      #104762
                      Bazyle
                        @bazyle
                        You could try searching the me & mew index for the lathe you are interested in and some similar names especially when it is sold by several vendors in virtually the same form.
                        I have often thought ME should do a quality in depth review of every major new lathe with systematic cross references to the similar ones as they come along and with detail about their rebadging and manufacturer. Not so much for today but for 50 years hence when their origins are long forgotten. Just look at all those 'what is this' queries on this forum and unknown lathes on ebay. It should be possible to find the details in past mags.
                        #104763
                        KWIL
                          @kwil
                          Bazyle, you must remember ME does not do anything, it relies and has always relied upon material being submitted. They are not staffed for writing only editing.
                          #104842
                          Bazyle
                            @bazyle
                            good point. they could solicit input from the mfr / importer and edit out the blatent advertising. Otherwise it could be a way for a new purchaser to earn a few bob back. I wonder if they want a review of an MT3 drill chuck smiley
                            #104854
                            Sub Mandrel
                              @submandrel
                              Why don't we start the ball rolling by posting threads in the workshop tooling topic? A few photos, how long you have had the machine, strengths and weaknesses and any modifications (both essential or convenient).
                              Similar machines (e.g. the various versions of mini-lathe could all share the same thread).
                              Edited By Stub Mandrel on 27/11/2012 21:13:58
                              #104855
                              chris j
                                @chrisj
                                Posted by Stub Mandrel on 27/11/2012 21:12:43:
                                Neil, you're alive smiley
                                #104942
                                Sub Mandrel
                                  @submandrel
                                  I've even got dry feet now
                                  Andyf
                                    @andyf
                                    Graham, if it's of any help, I have a small Warco lathe, and did a sort of review here on my website.
                                    Andy
