Lathe needed for 10-1/4 / 7-1/4
Home › Forums › Locomotives › Lathe needed for 10-1/4 / 7-1/4
  • #1466
    Ralph H
      @ralphh
      #209578
      Ralph H
        @ralphh
        I hope this may be a simple enough question but could anyone please advise what size lathe (at a minimum) would be needed to build an engine of say Britannia size in the above-mentioned gauges?
        The largest part I can swing is 26" diameter by 9" long.
        #209579
        Nick_G
          @nick_g
          Posted by Ralph H on 28/10/2015 12:39:49:
          I may be missing something but should the diameter and length be the other way round.?
          Nick
          #209582
            Probably the jobs likely to stretch the capacity of the lathe are:
            Turning driving wheels
            Smokebox ring
            Possibly flycutting underside of chimney.
            Bazyle
              @bazyle
              First look at the design and determine the two largest diameter items – the driving wheels and the smokebox to boiler joint ring.
              Then there are some simple approaches.
              1 Get a lathe that can turn these in the gap, it doesn't have to be able to turn them over the full bed.
              2 Get a lathe you can afford and fits your space available etc and if it is not big enough for some parts find an evening class, Men's Shed, club with a machine shop where you can do the few big items. Even if you have to travel a long way to access this facility it could be cheaper that the full works.
              3 Again get a small lathe but also look into how it can be temporarily enlarged with raising blocks under the head or by some add-on as has been published in ME occasionally.
              4 Again small lathe but also a milling machine with rotary table.
              5 Again small lathe but a combination mill like the Centec2b with horizontal spindle that can be also be used for turning, just not between centres.
              Quick estimate: Driving wheels 6ft 6in. at 10 1/4 that will need 13in capacity.
              Edited By Bazyle on 28/10/2015 13:14:19
              #209589
              Ralph H
                @ralphh
                Thank you gentlemen and sorry for not replying sooner, the box to reply has been blank and not able to be typed into. Just reappeared somehow.
                The sizes I give are correct – they are what can be swung in the gap of my largest lathe, see profile. It is 7 in. centres with 42 in. between them.
                I assume your replies were hindered by this? but the 13 in. capacity looks promising.
              Home › Forums › Locomotives › Topics
