I have some oilite bushes to fit to chassis side plates plus pinion gears to fit to motor shafts. Can you tell me what dimensions I should aim for to give a good interference fit.
Oilite bushes are usually oversize as supplied and press into a H8 reamed hole of the nominal size hole this will also close up the internal bore to the correct size. This will give you an idea of the clearances that meet H8
