imperial rule.
imperial rule.
Home › Forums › Workshop Tools and Tooling › imperial rule.
  • #18876
    mick70
      @mick70
      #346068
      mick70
        @mick70
        trying to find a 3ft rule with just imperial markings.
        it's going to inlaid into a bench my eldest daughter wants building for her design work.
        even though only 17 prefers what she proper measurements.
        similar idea to tailors bench.
        tried e-bay but no joy or not using right search words.
        #346070
        larry Phelan
          @larryphelan54019
          Might not be too easy to find,so I wish you luck.
          What,s wrong with Metric ? most clothing these days comes in Metric sizes anyway.
          #346071
          KWIL
            @kwil
            Try this.
            mick70
              @mick70
              perfect thanks Kwil will get one ordered.
              even got imperial at top.
              Larry it's not for clothing it's design work she does and as grown up with me using old style measurements.
              Edited By mick70 on 14/03/2018 14:35:41
              #346081
              Speedy Builder5
                @speedybuilder5
                Not exactly, but close ?
                Speedy Builder5
                  @speedybuilder5
                  And a wooden one
                  BobH
                  #346086
                  Chris Shelton
                    @chrisshelton11794
                    Hi a hunt for a yard stick on eBay turned this one up, item no
                    263270278507
                    HTH
                    #346087
                    John Reese
                      @johnreese12848
                      Have you considered self adhesive measuring tapes like this:
                      Speedy Builder5
                        @speedybuilder5
                        If the rule is for dressmaking, try to find a rule marked in 1/8" or 1/10" as smaller divisions would not be required. Perhaps ask if she works in 1/8 or 1/10" ??
                        BobH
                        #346091
                        Bazyle
                          @bazyle
                          As a model engineer shouldn't you be getting a nice piece of brass strip and engraving it, using the lathe leadscrew to set the dimensions?
                          #346107
                          Mike E.
                            @mikee-85511
                            I found this stainless steel rule at Poundland or Poundworld several months ago here in Wales. The edges were very sharp, but smoothed up nicely when stoned. One inch wide, thirty thousandths thick, and forty inches long. Its Imperial on one edge of the scale reading in 16 ths. and the other edge in 10 ths. of an inch. On the reverse side its Metric. Couldn't go wrong for a pound considering they were much more expensive else where. I believe, but not sure, I have seen them also in a chain store here in South Wales called……. " What ".
                            Edit: Sorry, for some reason I can't get photos to fall in sequence after my written post.
                            Edited By Mike E. on 14/03/2018 20:04:13
                            #346158
                            OldMetaller
                              @oldmetaller
                              How about an old boxwood folding carpenter's rule? You'd need to incorporate the brass hinges, but I think it would look nice.
                              John.
                              #346174
                              Douglas Johnston
                                @douglasjohnston98463
                                I have a couple of 60cm poundland ones but the scales are not spot on in terms of accuracy. Not a problem for most work but almost 1mm difference over 60cm between the two rulers.
                                Doug
                                #346180
                                  hwebber.co.uk (as per KWIL's link) do nice brass counter scales including an imperial only model. £70 might be a bit much though.
                                  #346192
                                  larry Phelan
                                    @larryphelan54019
                                    Hi Mick 70,
                                    No offence intended. I too grew up with feet and inches,but had no bother getting used to Metric. Now I use both,which is the more suitable for the job. It,s just that if you mention feet and inches to young people now,they look at you as if you came out of the Ark ! [but even Noah did not use that system ] Nice to know that long rules like that are still around,have not seen any of those mentioned by Mike E although I would like to pick up one of them if they show up here.
                                    #346202
                                    David Standing 1
                                      @davidstanding1
                                      Posted by larry Phelan on 15/03/2018 11:22:52:
                                      Same here.
                                      And I have one imperial and one metric lathe, and one imperial and one metric milling machine, so I am lazy sometimes and do jobs on whichever one suits the dimensions or specification of the job in hand.
                                      #346220
                                      mark costello 1
                                        @markcostello1
                                        Should have said something, I have several laying about and would gladly post one over.
                                        #346367
                                        Howard Lewis
                                          @howardlewis46836
                                          Some of the D I Y stores do Metre long rules with imperial along one edge, and Metric along the other.
                                          Mine's Aluminium, but suffices for "near enough" jobs.
