+1 for checking the line first with a dumb handset. BT aren't always right.
As hum can be caused in several ways, the approach (as others have indicated is to logically eliminate potential causes). Possibilities:
- Hum incoming on the BT line due to a BT fault. (Handset check as above)
- Failure of smoothing capacitors inside a wall-wart – try a different wall-wart (same volts, amps & polarity)
- A signal problem between the base unit and sub-stations – unplug both sub-stations. Change channel if you can, otherwise replace unit.
- Failure of decoupling or power capacitors inside the base station – replace unit.
Ferrites won't help. Once it's confirmed the BT line is OK, I wouldn't mess about trying to fix an aged phone. If changing the wall-wart doesn't fix it, replace the phone.
For interest, if you have to replace it, have a look inside the old phone before dumping it. I expect you'll find its made in a way that discourages repair by either amateurs or professionals – SMD components, multi-layer boards etc. Not impossible, but irksome.
Edited By SillyOldDuffer on 26/08/2018 09:29:27
