How to align a fixed steady?
Home › Forums › Beginners questions › How to align a fixed steady?
  • #524674
    Philip A
      @philipa30666
      This is my first workpiece that requires a steady. I'm not sure how to align the steady so that the workpiece sits staight. YouTube proposes a couple of methods, one very long winded which requires specialist tools and another method using a dial guage attached to the chuck. The dial guage method isn't working for me due to lack of space on the mini lathe.
      What methods are mini lathe owners on this site using?
      #10673
      Philip A
        @philipa30666
        #524677
        Jeff Dayman
          @jeffdayman43397
          I'd suggest a dial indicator with a magnetic base and stand. Mag base positioned on lathe bed top or front, indicator tip running on the end of the workpiece near centre front. adjust the steady's jaws until runout is near zero. That's it. The setup in your pic looks like there is lots of room for this method.
          #524678
          Emgee
            @emgee
            If the workpiece is running true and is circular then fit the steady to the bed as close as possible to the chuck, set the steady fingers to the job and lock off the bottom 2, slacken the top finger to allow the released steady to move along the bed closer to the end of the work then lock the steady to the bed and tighten the top finger to the work.
            Emgee
            #524679
            David Millar 3
              @davidmillar3
              Hi Philip.
              I've never used one either but I watched a doubleboost video on youtube yesterday where John set one up.
              He mounted the work in the chuck, set the steady around the work piece, close / adjacent to the chuck. Adjusted the steady so the fingers just made contact with the work piece. Then moved the steady to it's desired location. The logic being that the workpiece and chuck would be very close to concentic close to the work piece and errors increasing as you move away from the chuck.
              #524681
                Like Emgee I will chuck the work and just turn the chuck by hand to make sure it eyeballs true then set the steady close to the chuck locking the two lower fingers. Loosen top finger and slid esteady to end of job then set top finger.
                Can't see the point in using a DTI on the end as it could be indicating true but may be up down or sideways from the lathes axis and if so can start to walk out of the chuck when you start up. If you are going to use a DTI fit to carriage and run along side then top of the work to check it is parallel to lathe axis
                One I did last week
                Edited By JasonB on 04/02/2021 10:12:57
                #524684
                Former Member
                  @formermember12892
                  #524685
                  Tony Pratt 1
                    @tonypratt1
                    The supported & chucked end has to run true & the part has to be true to the lathe axis both in a vertical & horizontal plane. As the fingers need to touch the work there is always going to be some marking.
                    Tony
                    Edited By Tony Pratt 1 on 04/02/2021 10:18:09
                    #524688
                    larry phelan 1
                      @larryphelan1
                      I seem to remember that Sparey covered this issue in his book cheeky
                      #524697
                      DC31k
                        @dc31k
                        Posted by br on 04/02/2021 10:15:01:
                        How do you stop the fingers marking the material, just out of interest ?
                        One option is to use roller fingers. Small bearings can be used for this. Plastic bearings are also available. Wood turners use skateboard or roller blade wheels.
                        The trouble is that most steadies supplied as standard with a lathe are woefully small. I believe Hemingway offers a large capacity one and John Stevenson showed one made up of laser-cut steel sheets laminated together.
                        #524698
                        Ady1
                          @ady1
                          You don't need to align the steady, just make sure it sits right
                          It's the workpiece that needs aligning, use a dti
                          can take a while, a dead centre in the tailstock helps a lot, then remove it for final tweaks
                          edit you can use other systems like the cutting tool touching but if you want good accuracy you must get a dti system setup
                          GL
                          Edited By Ady1 on 04/02/2021 11:32:22
                          #524703
                          Anonymous
                            For quick 'n' dirty work I use the 3-jaw chuck and adjust the fixed steady to align a mark on the end of the bar to a centre in the tailstock:
                            For more accurate work I use a short length of stock in the 4-jaw, centred with a DTI, and then used to set the steady. Then the steady is moved, the workpiece installed and the chuck end checked with the DTI, as with this 30" long bar:
                            When the steady fingers are well oiled they don't seem to noticably mark steel or cast iron. If marking is a problem then use a ring of oiled paper between fingers and work.
                            #524711
                            Emgee
                              @emgee
                              I turned a nylon piece to be a close fit on the part diameter where the steady fingers were making contact, see in the video here. **LINK**
                              Emgee
                              #524724
                              Roderick Jenkins
                                @roderickjenkins93242
                                Posted by Ady1 on 04/02/2021 11:29:13:
                                GL
                                But not just checking the rotation. You also need to check the alignment along the length, vertically and horizontally, to ensure that the steady is not bending the workpiece. Setting the steady up at the chuck end then moving it along the bed to the required position has always worked for me.
                                Stay well,
                                Rod
                                #524728
                                Bo’sun
                                  @bosun58570
                                  DC31k mentions the use of small rollers instead of fingers. While this sounds like a good idea, I'd be concerned about small shavings being crushed into the workpiece. Fingers will simply brush the shavings aside. I have the same concern with roller blade guides on a wood bandsaw squashing resin onto the blade.
                                  #524735
                                  Ady1
                                    @ady1
                                    The chuck can mess things about too, especially if its a 3 jaw
                                    4 jaw is best, but more hassle to set up
                                    #524746
                                    John MC
                                      @johnmc39344
                                      My favourite method is to turn a short length of material to the same diameter as the work to be supported by the steady. Then set the steady to that. I also prefer to hold the work in a four jaw chuck so it can be held true. Inaccuracies can cause some interesting geometrical errors.
                                      In extreme, a poorly setup steady can cause the work to "walk" out of the chuck jaws.
                                        Posted by Emgee on 04/02/2021 09:55:29:
                                        Emgee
                                        THIS^
                                        old mart
                                          @oldmart
                                          I would align the workpiece first and then carefully bring the fingers into contact, using a dti to make sure that a minimum of deflection was present. If the work needed turning at the point where the fingers were going, I would attempt to turn a portion near the chuck and then turn the workpiece around if possible. I made a set of fingers with little ball races for less friction and no wear. As already mentioned, a collar could be used to run on if the marking was not desirable. A piece of card should be cut to form a barrier against swarf getting stuck in the fingers.
                                          Even with medium hard steel and rollers, marking is likely, the steady marks show on this spindle, but do not matter, fortunately.
