How should we describe non-metric tooling?
Home › Forums › The Tea Room › How should we describe non-metric tooling?
  • This topic has 79 replies, 47 voices, and was last updated 3 June 2017 at 08:07 by Michael Gilligan.
Viewing 25 posts - 1 through 25 (of 80 total)
  • #300540
    Tim Stevens
      @timstevens64731
      Many suppliers use the term 'imperial' for tooling based on inch measurements. The term actually means 'to do with an empire' and is quite helpful when referring to whitworth threads – which date to the time when we really did have an empire. But not for anyone from outside the empire, surely? We ex-imperialists might stretch the point to BSF and BA* – but NOT to threads from the USA such as UNF and UNC, or any of their predecessors or derivatives.
      Can I suggest that if you are selling inch-sized collets, or cutters, or similar things sized in fractions of an inch, the correct adjective is 'inch' ?
      *BA is a quandary, here, as its dimensions are metric, although it was standard throughout the empire (while we had one). So, BA spanners ought to be listed under 'metric' although few of them match any other metric sizes.
      Just a thought
      Cheers, Tim
      #34914
      Tim Stevens
        @timstevens64731
        Not ‘imperial’ – surely?
        #300541
        Brian H
          @brianh50089
          I think "Imperial" is an excellent description; everyone knows what it means. If it ain't broke don't fix it.
          #300542
          Andrew Tinsley
            @andrewtinsley63637
            Agreed!
            Andrew.
            #300546
            Tim Stevens
              @timstevens64731
              I'm sorry, Brian, but none of my dictionaries concur with your view. And they should know, surely, if 'everyone knows'.
              The Chambers Technical & Scientific dictionary gives eight meanings of imperial, and does not apply the term at all to threads or spanners or other tooling.
              Tim
              Edited By Tim Stevens on 31/05/2017 22:30:59
              #300547
              Nick_G
                @nick_g
                The USA as everyone knows still uses the 'imperial' system. But I hear on many Youtube videos them still calling it 'the English system'
                While slightly off topic-ish I was taught metric at school but for engineering I feel far more comfortable using Imperial.
                Nick
                #300549
                AndyP
                  @andyp13730
                  I've always liked "footric" but I don't suppose it will catch on, let's just stick with "proper" wink
                  Andy
                  #300551
                  Dod Mole
                    @georgeclarihew
                    We could call non imperial ( esp. 'merican ) the " colonial system " and see what reaction we get. devil
                    #300552
                    S.D.L.
                      @s-d-l
                      Posted by Nick_G on 31/05/2017 22:30:47:
                      Nick
                      The US term is USCU United States Customary Units which was based on the English units before they were revised to Imperial (1824) and are defined it terms of metric units
                      Some Americans I have met don't accept the Imperial tag at all.
                      Steve
                      #300553
                      MW
                        @mw27036
                        I believe in 1948 there was an international agreement between the U.S and U.K to tie up their systems so that you could easily switch between the two.
                        If you consider the fact that the U.S (13 colonies) was a colony started by and large the british as well as governed. With the capital in Virginia as opposed to Columbia like it is now. They are kinda using the same system. and even more so when you consider the above stated.
                        'The British Standards Institute defined the inch as 25.4mm in 1930 in the document "Metric Units in Engineering: Going SI". In March 1932 the American Standards Association were asked to rule on whether to adopt the same value (at the time the American inch was 1/.03937 mm which approximated to 25.400051 mm). Because the values were so close, and because Britain has already settled on that value, the ASA adopted this value on March 13, 1933.'
                        ​​There was apparently a Scottish Inch at one point too. One might say that the units themselves, pertaining to latin in origin, are older than the term for the whole system. And hence why they crop up in pre-metricated European nations too.
                        Michael W
                        Edited By Michael-w on 31/05/2017 23:09:21
                        #300554
                        Brian G
                          @briang
                          Nick
                          I understand that over the pond, inches, gallons etc. are officially known as "US Customary Units". They aren't imperial as they rebelled before the British Empire was formed, hence their use of Queen Anne's wine gallon instead of the 1824 Imperial Gallon. Within Europe, and particularly Germany, pre-metric inches can vary significantly from country to country or even city to city. **LINK** Interestingly, the 25.4mm inch is described there as the "Imperial Inch".
                          #300555
                          Gray62
                            @gray62
                            Why are we always looking to find new ways of describing what has been around for decades or centuries, Imperial units were defined in The Weights and Measures Act of 1824, Why does anyone feel the need to find an alternative description. It is what it is.
                            #300556
                            Dod Mole
                              @georgeclarihew
                              Scottish inch, Royal mile – not the same size as a southern one, and lots of other variations of weight, length, Oh and the Scots pound, might get more popular after leaving the Eeeyou and we stay. devil devil
                              #300557
                              Nick_G
                                @nick_g
                                Posted by Michael-w on 31/05/2017 22:58:29:
                                Michael W
                                I know that yappy dog Sturgeon does not look very tall but surly she cannot be that small.? wink
                                Nick
                                #300575
                                Ady1
                                  @ady1
                                  ooh, I like that one.
                                  Proper imperial that is, yoop
                                  #300577
                                  Ady1
                                    @ady1
                                    Scottish inch
                                    Proper imperial units
                                    Edited By Ady1 on 01/06/2017 01:19:35
                                    #300579
                                    Rik Shaw
                                      @rikshaw
                                      Imperial is imperial, why try to fog it?
                                      Rik
                                      #300580
                                      Ady1
                                        @ady1
                                        A quiz question one, a chain
                                        10 chains in a furlong
                                        80 chains in a mile
                                        10 square chains is an acre
                                        Edited By Ady1 on 01/06/2017 01:28:28
                                        #300581
                                        Ady1
                                          @ady1
                                          The chain also survives as the length of a cricket pitch, being the distance between the stumps.
                                          #300589
                                            Tim,
                                            Have you been to Trafalgar Square ?
                                            Edit: Oops,  Ady's link has already referenced the Imperial Standards.
                                            Edited By Michael Gilligan on 01/06/2017 06:47:04
                                            #300591
                                            Hopper
                                              @hopper
                                              ISTR from when I lived in the USA for several years that almost nobody there knew or cared what the Imperial system was. And even fewer seemed to know the metric system existed. To them, there was just the system — the inch system they used daily.
                                              But for me, Imperial works just fine. It's what it has always been called and seems to work. The empire may be gone but the echoes still reverberate across the world via a multitude of old machines.
                                              #300596
                                              Raymond Sanderson 2
                                                @raymondsanderson2
                                                You do realise that the US inch is different to the Imperial inch!!!!
                                                Decimal or metric is used by European because they never considered 360" / 12 they only counted their 10 fingers or that its 12 months to a year.
                                                If the Scot's get FREEDOM will they revert to their measurement also??
                                                #300605
                                                  Posted by Raymond Sanderson 2 on 01/06/2017 07:10:07:
                                                  … was different devil
                                                  I quote, from your link:
                                                  Traditional standards for the exact length of an inch have varied in the past, but since the adoption of the international yard during the 1950s and 1960s it has been based on the metric system and defined as exactly 2.54 cm.
                                                  Edited By Michael Gilligan on 01/06/2017 08:02:50
                                                  #300614
                                                  richardandtracy
                                                    @richardandtracy
                                                    Over the years in England we have been through at least 4 different lengths for the foot with the Anglo-Saxon foot of 335mm  -13.2 current inches-   being one of the longest variants. This page shows some of the absurd units we've used over the years **LINK** .
                                                    Richard
                                                    Edited to remove accidental emoticon
                                                    Edited By richardandtracy on 01/06/2017 08:37:54
                                                    #300615
                                                    roy entwistle
                                                      @royentwistle24699
                                                      Re How should we describe non- metric tooling. Can I suggest " Proper "
                                                      Roy devil
