Hot air gun
Hot air gun
Home › Forums › Workshop Techniques › Hot air gun
Viewing 15 posts - 1 through 15 (of 15 total)
  • #216278
    Speedy Builder5
      @speedybuilder5
      Is this really possible at 600 Deg C ??  Click on the picture of bending copper water pipe (15 mm ?)
      BobH
      Edited By Speedy Builder5 on 14/12/2015 09:06:41
      #15820
      Speedy Builder5
        @speedybuilder5
        Bending copper tube
        #216285
        Brian Wood
          @brianwood45127
          Not without a pipe spring inside, which of course they don't show. Unsupported, it will crease and fold up every time, hot or cold. Even with a spring inside it needs pulling round your knee, you can't expect it to flow like plasticene
          I don't believe the claimed working temperature either, boyo would have a job holding copper pipe at that temperature in his bare hands that close to the heat source.
          Very large doses of advertising puff here I think.
          Edited By Brian Wood on 14/12/2015 10:00:39
          #216287
          Gordon W
            @gordonw
            All I get with the link is a screwfix ad. ! They are usually pretty good with claims.
            #216296
            mechman48
              @mechman48
              … All I get with the link is a screwfix ad. !
              Same here..?
              #216299
              roy entwistle
                @royentwistle24699
                Same here
                #216301
                Brian Wood
                  @brianwood45127
                  You have to click twice, close the overall Screwfix ad and do it again.
                  Product code 68560, De Walt hot air gun
                  Edited By Brian Wood on 14/12/2015 11:11:53
                  #216304
                  Gordon W
                    @gordonw
                    Still can't get it- better things to do.
                    #216309
                    Nicholas Farr
                      @nicholasfarr14254
                      Hi, here it is **LINK** at £46.99
                      Regards Nick.
                      P.S. Bob's link appears to be an EU web page and it is priced at 63.99 euros
                      Edited By Nicholas Farr on 14/12/2015 11:44:09
                      #216365
                      mechman48
                        @mechman48
                        Not enough distance between hands to get the required leverage to bend pipe, plus it must have been done on a pipe bender initially, or as Brian says with a pipe spring inside, & then bent on his knees… oh we poor mortals; to be taken in by such succinct advertising.
                        George.
                        #216372
                        Speedy Builder5
                          @speedybuilder5
                          Yes, Thanks Nick, the web site picks up my IP address in France. By my question was – Is 600 deg C really hot enough to alter the properties of a piece of copper pipe to make it easier to bend. I didn't think it was.
                          Incidentally, I quite often bend 15mm pipe (16mm here in France) around a gas bottle without a spring after annealing. 22mm takes a bit more grunt !!
                          BobH
                          #216385
                          Brian Wood
                            @brianwood45127
                            Hello Bob,
                            I bet you get quite a lot of flattening doing it that way.
                            #216388
                            Speedy Builder5
                              @speedybuilder5
                              Nope – The secret (if you can call it that) is to anneal the tube first, heat to dull red and quench in cold water. "As Drawn", you have no chance.
                              #216389
                              Nicholas Farr
                                @nicholasfarr14254
                                Hi Bob, well apparently 600 deg C is hot enough, see this **LINK**. However, I don't know if you would be able to get the required amount of heat into a piece of copper pipe shown in the ad, and probably not before it started to burn your hands, even though the ad shows the guy doing it with gloves on. I've had to anneal 15mm copper pipe to do some plumbing jobs and needed a fairly big propane flame in free air and it takes a bit of doing over the length that the ad seems to show. But what do I know.
                                Regards Nick.
                                #216409
                                the artfull-codger
                                  @theartfull-codger
                                  Looks a load of rubbish to me, one of the easiest ways to bend plumbing pipe if it's hard is to anneal it[heat to red] quenching in water does nothing to the annealing process other than cooling it & helps some of the scale to come off then put a pipe spring up the bore.
                                Home › Forums › Workshop Techniques › Topics
