Holding large milling cutters in an R8 spindle
Home › Forums › Workshop Tools and Tooling › Holding large milling cutters in an R8 spindle
  • #360061
    lfoggy
      @lfoggy
      I've just acquired a 'job lot' of new milling cutters consisting of mainly 6-20mm slot and end mills. Included however were 7 new Dormer end mills with 25mm and 1" threaded shanks. I have a mill with an R8 taper and usually use R8 collets to hold cutters. Max size for these is 20mm I believe. These new cutters are too good to waste so I need to find a way of holding them. Looks like I may need to buy an ER40 collet chuck and holder but are there any other options?
      #18977
      lfoggy
        @lfoggy
        #360062
        colin brannigan
          @colinbrannigan54160
          There is a R8 collet which will take either 25m or 1" dia cutters can't remember which, but I don't like them have seen too many break under decent cuts, go for ER 40 R8.
          Colin
          #360064
          Chris Evans 6
            @chrisevans6
            ER 40 is most likely the best option. I use a Clarkson chuck for my 1" shank stuff on the R8 equipped Bridgeport, downside is that with threaded shanks you cant easily get that extra 1/4" reach without turning up a centred spacer to fudge the job. ER 40 are cheap now so decision is easy.
            #360083
            Mike Poole
              @mikepoole82104
              A carbide lathe tool will turn the shank of a HSS cutter down to a suitable size.
              #362806
              Bob Astill
                @bobastill76884
