Help with measuring a bore
Home › Forums › Help and Assistance! (Offered or Wanted) › Help with measuring a bore
Viewing 15 posts - 1 through 15 (of 15 total)
  • #33184
    Joe McKean
      @joemckean81940
      #349256
      Joe McKean
        @joemckean81940
        I am in the process of restoring a older motorcycle and need to machine new pistons to fit into the fork sliders, unfortunately I am having trouble measuring the internal bore of these as I only have telescopic bore gauges and I'm not getting consistent measurements, as the pistons need to be 3 thou under the size of the bore I need help in getting the correct measurement so is there anyone within a hours drive of Corby in Northamptonshire that could accurately measure these for me. The internal diameter of the sliders is approximately 31 – 32mm. any help with this would be very much appreciated
        Joe
        #349261
        Alan Waddington 2
          @alanwaddington2
          Just a thought Joe, could you not turn up a plug out of Ali or similar that is a snug fit in the slider and then mic that up.
          #349263
          Mick B1
            @mickb1
            If you're getting inconsistent measurements, do you think the bores are actually round and parallel, or are they worn unevenly?
            Is it practical to ream to a known diameter and make a piston to suit that?
            #349297
            John Reese
              @johnreese12848
              As Mick B1 said the bores may no longer be round or straight due to wear. Try to borrow a bore gauge with a dial indicator.. Use it to explore the bore to see what condition it is. It may no longer be round or cylindrical. It may be necessary to hone them to make them cylindrical.
              #349314
              thaiguzzi
                @thaiguzzi
                Posted by John Reese on 08/04/2018 00:17:20:
                What he said.
                Machine DRO on this page sell bore guages at very reasonable prices.
                #349321
                Hopper
                  @hopper
                  You don't share the make or age of motorcycle with us, but generally speaking, many old bike tele forks were made from seamless tubing. The inside diameter was not machined, merely left as rolled. So they may well not be perfectly round nor perfectly parallel. Mostly the pistons were made a loose fit and relied on the piston rings, or O rings in later years, to seal.
                  +1 on make an ali plug that you can fit the end of the fork leg over while plug is still in the lathe and size it that way. Then bung it on the end of a bit of rod and run it up and down both fork legs to check it will slide all the way up and down without binding. If it binds, knock a couple thou off and try again etc. Then turn your pistons to that final size.
                  #350052
                  Bob Astill
                    @bobastill76884
                    Where are you i use digital and analog bore gauges all the time and have several maybe i can help i am between Grantham and Newark.
                    Bob
                    #350058
                    not done it yet
                      @notdoneityet
                      Bob,
                      Joe has no profile in his settings, but did say ‘within an hour of Corby, Northants’ in his opening post.
                      #350059
                      Chris Evans 6
                        @chrisevans6
                        I do a lot of motorcycle fork work, they are never very good for being round. Go with the Ali plug idea, you don't want them that tight that they won't slide. I now use glass filled PTFE rod to make the bushes and they slide well.
                        #350119
                        Joe McKean
                          @joemckean81940
                          Hi Bob I have sent you a message.
                          Joe
                          #350131
                          old Al
                            @oldal
                            I think Joe is making his life hard for himself. If it were manufactured in imperial measurements, it makes sense to measure in imperial measurements. Then at least the start measurement becomes obvious with simple measuring tools.
                            #350138
                            Joe McKean
                              @joemckean81940
                              Italian motorcycle therefore manufactured in metric, maybe I should have said 0.07619 mm instead of 3 thou tolerance.
                              Work in metric and imperial sometimes even at the same time with no problems just have to make use of a calculator now and again.
                              #350266
                              Jon
                                @jon
                                Wouldnt be Marzochis would they.
                                He is referring to the bore in the aluminium precision machined legs (unless worn oval) not bore of the precision fixed harder steel tube that slides within, no play.
                                Analogue bore guages just as good as digi. Much easier for me to put you on to a good guide regarding usage and eliminating errors on youtube. One of many https://www.youtube.com/watch?v=R6YLK0F3ytc
                                Have reservations non twist/rock to find centre before locking up. If off centre bore will be smaller!
                                #350270
                                JohnF
                                  @johnf59703
                                  Joe why not consider a bore gauge see this link, not too expensive and useful afterwards ,
                                  Another alternative measure best you can with the tele gauge then make a multi stepped plug gauge in 0.002" steps, the steps don't need to be very long, then when you are confident of being very close to the size make or alter the gauge to longer steps and test again, last make/alter the gauge to the final size and test. About 2" of aluminium bar should suffice.
                                  Edited By JohnF on 15/04/2018 15:54:40
