Heads up! Granite discs, £2, B&Q.
Home Forums Materials Heads up! Granite discs, £2, B&Q.
  • #29902
    wilson logan 1
      @wilsonlogan1
      wilson logan 1
        @wilsonlogan1
        Hi All,
        I saw these advertised outside at my local B&Q (were £7 each).
        About a foot across by 3/4 thick. Reasonably smooth on one side. Other side is a bit rough. The two on display were chipped but there were plenty good ones on the pallet.
        They're a reasonable size without being too heavy.
        You could lap three together.
        Worth thinking about for £6…
        Cheers,
        Wilson.
        #402097
        Douglas Johnston
          @douglasjohnston98463
          Granite discs can also be used for the base of things like tapping fixtures. Nice and heavy and stable and cheap as chips if you can get them for £2 a pop.
          Doug
          #402125
            Another idea is to contact a kitchen fitter and see if they have any offcuts of epoxy/granite composite worktop (e.g. the bit cut out for a sink)
            Plasma
              @plasma
              Our local worktop guy will provide off cuts to size polished and bevelled etc.
              My surface plate is made of one such and several models have polished granite bases.
            Home Forums Materials Topics
