Grinding wheel bores?
Home › Forums › Workshop Tools and Tooling › Grinding wheel bores?
  • #656102
    Mike Hurley
      @mikehurley60381
      I have a lovely record double ended bench grinder that runs nice and smoothly. Today, I came to the point of changing one of the original wheels with a replacement i've had 'in stock ' for years. Each spindle end has a pair of machined flanges, one including the hub for the wheels bore.
      Tries to fit the new wheel, wouldn't fit. (bad language omitted at this point). After examining the labels on the wheels the original shows bore as 32mm new ones 31.75mm. This machine only dates back to 1995 and I'm surprised to find this difference. As 31.75 now seems standard – when did this change?
      It looks like I shall end up very carefully skimmimg the hub to the 'new standard ' size.
      Most of the usual mainstream tools suppliers don't seem to stock traditional 150mm wheels (or hold just a limited range ), anyone got experience of a reliable supplier of good wheels (I'm perhaps a bit dubious of buying unknown brands off ebay / amazon ) ?
      regards
      #21053
      Mike Hurley
        @mikehurley60381
        #656103
        john halfpenny
          @johnhalfpenny52803
          Yes, I've known a few (well, someone had to say it)
          #656108
          Bo’sun
            @bosun58570
            Coincidence maybe, but at the moment (literally) I'm also looking for good quality wheels for my 6" ELU grinder, so any suggestions would help me too.
            Thanks
            #656123
            Mark Rand
              @markrand96270
              I tend to buy my wheels from Abtec. The 32mm/1.25" thing is a problem. I've been caught out by it before. My solution was to open the bore of the affected wheels with a 32mm Rotabroach cutter, by hand (Que gasps of horror and warnings of explosions by the ignoramuses in the audience).
              #656133
              File Handle
                @filehandle
                Posted by Mark Rand on 11/08/2023 16:48:26:
                In my teenage years, I opened a green 4" wheel by the very crude method of drilling it out with an old drill bit. This was 50 odd years ago. It still gets occasional use. I am not in anyway recommending this method, but it worked.
                #656139
                DMB
                  @dmb
                  New wheels should come with a set of plastic (these days) bushes of various sizes. There was a time when lead bushes had to be made to fit wheel and grinder shaft. It's possible that the bushes have to be purchased separately, can't remember, long time since last purchased a new wheel. I certainly wouldn't buy any old junk wheel from the second hand tool trade. Cannot afford to take the risk of a shatter.
                  duncan webster 1
                    @duncanwebster1
                    I got my last one from Axminster, mainly because they have a branch local, but it seems fine, stopped the grinder walking around the bench when it had its original wheels. Not sure I'd buy one by post, I've seen how they throw packages around, and you don't want to see the results of a wheel giving way at speed
                    #656162
                    Oily Rag
                      @oilyrag
                      Try Midland Abrasives Ltd, Hockley, Birmingham (0121 687 1135) – Very helpful people and will modify wheels to your requirements. I needed a new wheel for my toolpost grinder and they sent me one they had cut down from a metric size wheel as the original o/d was obsolete. This they did at no extra cost. They also recommend the grit and bond you require if you tell them what you are mainly interested in grinding.
                      No connections other than a very satisfied customer.
                      Martin
                      0
                      Edited By Oily Rag on 11/08/2023 20:53:25
                      Edited By Oily Rag on 11/08/2023 20:53:59
                      #656166
                      noel shelley
                        @noelshelley55608
                        I'm affraid my dealings with midland abrasives were not so good – Yes helpful But ! The first wheel was badly out of balance. The second was also badly out of balance, the third was sent free of charge but also badly out of balance ! Only when I bought a J&S dalancer did I find out how bad the balance was – it made the machine it was fitted to unusable ! Noel.
                        #656196
                        not done it yet
                          @notdoneityet
                          I would be considering reaming the parts to 32.00mm. Might not, of course, depending on the situation ‘in the flesh’.
                          #656206
                          DMB
                            @dmb
                            Duncan,
                            The last cup wheel that I purchased arrived by Royal mail in perfect condition, well wrapped in a cardboard box. Can't now remember where from but it wasn't a model engineering supplier, it was one of the general engineering businesses. Not out of balance, just needed a suitable conversion bush. I think that I had to purchase a set of plastic ones at additional cost but not certain as it was several years ago.
                            DMB
                              @dmb
                              Further to my previous post, it could have been Cromwell Tools
                              Mike Hurley
                                @mikehurley60381
                                Appreciate you comments & suggestions chaps.
                                Having looked at many suppiers info etc it seems that most wheels are commonly available with the 31.75 bore. 32 are around, but seems less choice overall, so I made the executive decision to adjust the hub rather than the stone.
                                Knocked up a quick arbor, fitted the hub / flange casting and checked concentricity with the old DTI. Skimmed fine, fitted back on the grinder with the new green wheel & works fine. Will do the other end as & when I need to change the wheel next
                                regards to all
                                #656324
                                Pete Rimmer
                                  @peterimmer30576
                                  Smart move I say. One thing you never want to do is fit a grinding wheel onto a spindle/arbor that it's a tight fit onto. I turned an arbor once for a wheel and it was a fairly snug, but not terribly tight fit. It (the wheel) broke whilst I was fitting it. A very scary lesson learned way back, I was shocked at the ease which the wheel shattered.
                                  #656340
                                  Mike Poole
                                    @mikepoole82104
                                    Is 32mm a standard size? or a generous rounding up of 31.75mm which is 1 1/4” exactly I would rather machine a 32mm arbor down to 31.75mm and deal with the gap if 32mm wheels arrive.
                                    #656351
                                    Mike Hurley
                                      @mikehurley60381
                                      My assumtion is that it is / has been a 'standard ' size. The labels on the original stones clearly state 32mm
                                      Looking at the ABTEC listings kindly recommended clearly show a few specifically stated as 32mm bore, with the majority of others being 31.75. I don't think its just an 'old ' standard thats gone out of use as I've seen quite a few of the modern diamond wheels also listed as 32mm bore.
                                      So the answer is, I don't know. Just another of life's little irritations?
                                      #656352
                                      Mark Rand
                                        @markrand96270
                                        Both 1 1/4" and 32mm are standard sizes, unfortunately…
                                        #656354
                                        bernard towers
                                          @bernardtowers37738
                                          Mike, Take it out carefully with an adjustable reamer.
                                          #656358
                                          Tony Pratt 1
                                            @tonypratt1
                                            Anyone got a 32mm adjustable reamer to hand?
                                            Tony
