Gear
Gear
Home › Forums › General Questions › Gear
  • #653657
    Milly S
      @millys
      Hi all
      I’m after a 46 tooth gear for Chipmaster
      the one that came with machine has tooth
      missing tried eBay with no luck any help
      appreciated
      cheers
      steve
      #29303
      Milly S
        @millys
        46 tooth
        #653659
        Howard Lewis
          @howardlewis46836
          Lathes UK may provide more details, or what other lathes used the same, or a similar, gear, (possibly other Colchester lathes? )
          With details of the gear, either, you mat find someone like Davall, Reliance or HPC gears could provid one (At a PRICE, no doubt )
          Failing bthat, armed with the details, (DP, Pressure Amgle ) you may find someone who woulf make mone for you.
          You will beble to provide the other details, tooth width, bore etc from the gear that you have.
          #653660
          bernard towers
            @bernardtowers37738
            Run a slot drill through the place where the tooth is broken insert repair piece ,silver solder in and dress back to shape.
            #653665
            Neil A
              @neila
              You could try the following if you have not already, you might be lucky.
              https://www.colchesterspares.com
              not done it yet
                @notdoneityet
                Alternatively, as it is only one tooth missing, simply repair it!
                #653672
                Howard Lewis
                  @howardlewis46836
                  Once had a missing tooth on a steel gear repaired by an ACE welder. And then machined the weld back mto size, having located off the other vteeth.
                  Sadly, he moved away overseas!
                  If your gear is cast iron, as I suspevct, you could braze a replacement into place and machine , with na suitable gear cutter, or file the repair back to the correct shape.
                  #653677
                  Bazyle
                    @bazyle
                    How long have you been checking ebay? 3 months?, 6? It is not a supermarket so don't exxpect there to be a continuous supply.
                    #653678
                    noel shelley
                      @noelshelley55608
                      Most likely cast iron but it still can be repaired may be by brazing and filing Worth a go ! Noel..
                      #653679
                      Bo’sun
                        @bosun58570
                        Hi Milly S,
                        Have you tried "Home and Workshop Machinery"? They advertise Colchester change wheels. Not sure about Chipmaster ones though.
                        #653684
                        DC31k
                          @dc31k
                          Posted by Milly S on 25/07/2023 16:40:20:
                          Please can you confirm that it is a change gear you require.
                          Are you absolutely 100% sure on the tooth count?
                          If you look through the Chipmaster manual, a 46t gear was not offered by the factory either for the imperial or the metric version of the machine.
                          The only use for a 46t gear, being 2 x 23 or 4 x 11.5 is to cut US NPT pipe threads. In the manual, both the imperial machine and the metric machine use a 69t gear for this purpose.
                          Hence, if you do have a 46t gear, it will be of third party manufacture.
                          #653817
                          Milly S
                            @millys
                            Hi all sorry it wasn’t 46t it is 48t eyes not
                            as good these days
                            Cheers
                            steve
                            #653819
                            Nigel Graham 2
                              @nigelgraham2
                              If you need buy a gear from a stockist like HPC etc, they are normally sold with pilot bores for you to machine to correct bore.
                              Be careful the pressure-angle of the replacement matches that of the existing set, though it may not be so critical if only used once in a blue moon.
                              #653822
                              Pete Rimmer
                                @peterimmer30576
                                HPC only do 20 degree gears and that colchester probably uses 14.5 degree gears.
                                #653828
                                Tony Pratt 1
                                  @tonypratt1
                                  There is a Colchester and Harrison lathe owner’s group on Facebook, may be worth asking them?
                                  Tony
                                  #653829
                                  Tony Pratt 1
                                    @tonypratt1
                                    Tony
                                    #653848
                                    DC31k
                                      @dc31k
                                      As it is a 48t gear, that implies that you have a metric (Continental) Chipmaster.
                                      The Continental is less often seen than the imperial version so that might make finding a replacement difficult. The other issue is that with 48t, it would come from a set of gears 'by fours'.
                                      Other lathes that use the same 14DP 14.5 degree PA gears are Harrison L5 and 140, Drummond and some early larger Colchesters. Someone might know if 48t was part of the Drummond or Harrison set.
                                      The gear is quite important for most metric threads. It is used as either 28/48 or 56/48, which reduce to 7/12 or 7/6.
                                      You would have to check if the gears would fit the space available, but it is possible to reproduce those two ratios with 35/60 and 35/30. Coming from a gear set 'by fives', they might be easier to find.
                                      The other difficulty is the six-spline centre detail of the gear (it is the same as Boxford X10 models) – you could re-use the broken gear if you find a single 48t replacement, but if solving the problem involves more than one gear, how do you make more than one new centre?
                                      #653849
                                      not done it yet
                                        @notdoneityet
                                        It’s not a high power job, so three grubscrews fitted with loctite and filed/machined to profile would do the job perfectly adequately. I usually fill with braze and recut the teeth with a bought-in (or home ground) cutter. Too much of a ‘throw-away’ society these days, if you were to ask my opinion.
                                        #658326
                                        Derek cottiss
                                          @derekcottiss41883
                                          if you didnt get sorted send me a pic and sizes i have a box of colchester change wheels
