flywheel cut out spacing
Home › Forums › Help and Assistance! (Offered or Wanted) › flywheel cut out spacing
  • #359544
    bricky
      @bricky
      I am making Brian Rupnow's Rockerblock engine.Unlike Brian I don't have access to laser cutting for the spaces to form spokes.I am drilling 1" holes instead.My question is dose it matter if I have an odd number or do they have to be even.There are two flywheels.
      Frank
      #33226
      bricky
        @bricky
        #359545
        Brian Wood
          @brianwood45127
          Hello Frank,
          I think odd looks better but you can convince yourself with a paper drawing, full size, and experiment before you cut metal. That way you can also get what looks to be a pleasing hole diameter as well
          #359552
            Provided they are equally spaced to keep the flywheel balanced you can have however many cutouts you like and whatever shape you like.
            #359557
            bricky
              @bricky
              Thanks for the advice ,will have five, I knew I would get an answer quickly .
              Frank
