Fitting Python file handles – advice please?
Home › Forums › Beginners questions › Fitting Python file handles – advice please?
  • #345841
    Hillclimber
      @hillclimber
      Any advice on fitting Python file handles? I've decided I'm too old to enjoy using the few rubbery-plastic ones I have – too pyongy. Hence a regime shift in favour of Python.
      Is there anything particular I need to know about the 'hidden spring'? Best to drill out a bit? Or just use the 'hot tang' burn-in method?
      Cheers, Colin
      #9132
      Hillclimber
        @hillclimber
        #345847
        Vic
          @vic
          Where I used to work they just “ shoved it in” blush never noticed any problems!
          #345851
          old Al
            @oldal
            Hot tang always works for me
            #345856
            Nick Hulme
              @nickhulme30114
              Push the file in as far as you can under your own steam then bang the file handle down firmly on a smooth surface with plenty of mass, I use my anvil, a few sharp strikes and I've never had one fall out.
              #345858
              Clive Foster
                @clivefoster55965
                Some discussion here :- **LINK**
                Multistep process seems bit long winded but does, theoretically, avoid over-burning the hole.
                Theory of the spring is that it forces the softwood handle around the final part of the tang under the ferrule giving a good grip without needing to burn the big end of the hole to shape.
                Sort of thing you need to do to make a cheap, relatively crappy, handle work. Back in ye good old days with proper turned brass ferrules the handle cost around half as much as the file so you looked after it and expected it to do several files. Of course a file was a days wage or so too. Was years before I could justify new files as opposed to reconditioned ones via Mr Whistons (in)famous Cat on its log.
                #345960
                Hevanscc
                  @hevanscc
                  You should push the tang into the handle and then, holding the wooden handle with the file facing down, strike the end of handle with a mallet. Somewhat counter-intuitively, this will force the tang into the handle rather than knock it out. You can look up the physics if you don't believe me.
                  Hywel
                  #345961
                  Hevanscc
                    @hevanscc
                    Hywel
                    #346003
                    Hillclimber
                      @hillclimber
                      *Newton's third law*
