Finish when Milling with SX3
Home › Forums › Beginners questions › Finish when Milling with SX3
  • #633309
    James Hall 3
      @jameshall3
      Here's another newbie question:
      When milling using the side of end mills (particularly on steel) I get a slightly 'wavy' or 'rippled' finish; this is not confined to one particular cutter or size.. I'm pretty sure I'm using the correct rpm for the cutter size and still find this despite varying cut depths and feed rates or combinations.
      Can you old hands throw any light on this, please and advice on overcoming the problem. The effect is shallow enough that it can be sanded away but would prefer not to have to.
      #11418
      James Hall 3
        @jameshall3
        How to avoid ‘wavy’ finish using end mill.
        #633354
        Ady1
          @ady1
          Perhaps a very high speed finishing cut would sort it
          (or a finishing cut on a bridgeport !)
          I get the same effect on my home made mill but it's not very stiff/heavy
          Edited By Ady1 on 13/02/2023 23:28:36
          #633357
          samuel heywood
            @samuelheywood23031
            I remember getting that effect when i was starting the learning curve (this is on a mere X1 mind you. )
            Sorry, but i can't remember how i fixed it 5yrs ago!!~ was due to play or backlash or flex somewhere in the system.
            I'm sure someone can pinpoint the EXACT cause for you.
            & if my little X1 can do it, I'm sure your X3 can.
            #633362
            Hopper
              @hopper
              Are you conventional milling, against the direction of rotation of the cutter, or climb milling in the same direction as the rotation?
              Do you have all slideways locked except the one needed to allow the motion of feed?
              What size cutters are you using?
              #633370
              Paul M
                @paulm98238
                With my Warco VM16 I use conventional milling for all cuts apart from a fairly light finishing cut climb milling. Tend to use HSS cutters on most materials and coolant. Everything locked down.
                #633371
                Martin Connelly
                  @martinconnelly55370
                  RPM, locking up unused ways and machine rigidity are not the only thing that matter. In order to cut there needs to be a big enough bite into the workpiece from the cutting edge. Too small and it will rub the surface, too big and it will damage the cutter. To get a good finish requires a steady motion at a suitable speed. Anywhere where the tool is paused will be rubbed below the surface that can be cut. This rubbing is not good for either the finish or the cutting edge of the tool.
                  When someone refers to speeds and feeds these are the two factors that are being talked about. Speed is the rate at which the cutting edge is passing over the surface it is cutting and is calculated from the RPM and the diameter of the cutter. Feed is how fast the tool axis and workpiece are moving relative to each other. Feed is used to obtain a sensible cut each time the cutting edge engages with the workpiece. For example, if you have a single cutting edge on a tool rotating at 60 rpm and travelling 3mm per minute the tool will rotate 60 times in that minute and feed 3mm at the same time. The chip thickness will be 3mm / 60mm/s­ = 0.05mm. Two cutting edges on the tool will halve the chip thickness to 0.025mm.
                  Doubling the rpm of the single edge tool will also halve the chip thickness from 0.05mm to 0.025mm.
                  So, going back to the original problem, if you are using a feed rate that is too slow then there may be times when the tool is dwelling in one spot and rubbing. If you are using powered feed that is too slow the tool can go from cutting to rubbing to cutting. The chips that are coming off should give some indication of correct feed, you do not want very fine slivers, they should be discrete chips.
                  Another factor is tool flex. How much stick-out is there? A long thin tool will deflect much more than a short fat tool. A 3 or 4 flute cutter is more rigid than a 2 flute tool. Adaptors that extend the tool out from the spindle (R8 to ER for example) can increase the stick-out as well.
                  There is one other factor that can cause alternation between cutting and rubbing and that is the state of the bearings of the spindle. If you have a relatively new machine it is possible that the bearings have started to settle in place and may need adjusting to take up some slack. An older machine needs adjustment if the bearings start to wear. A simple test for correctly adjusted bearings is that they should get warm but not hot when working. So the question is, if you run the spindle at full rpm for about 15 minutes but doing no work with the machine do the bearings at the top and bottom of the spindle get warm to the touch, stay cold or get too hot to touch. Warm is what you want. Frequent need to adjust the bearings means they need replacing.
                  Martin C
                  Edited By Martin Connelly on 14/02/2023 08:58:40
                  #633374
                    Climb vs Conventional milling maybe?
                    Climb milling is more efficient and produces better finish provided the machine is beefy enough. Hobby mills are rarely rigid enough for climb milling – they vibrate – so the technique is best avoided.
                    Except, I often climb mill on the final cut because it improves finish. It's rarely necessary to adjust anything: after conventionally milling off the last deep cut, the work is backed out against the spinning cutter so it does a very light climb cut. This often improves finish.
                    When diagnosing workshop problems I always check the three main culprits:
                    • The tool (worn, design limitation, needs adjustment etc.)
                    • Operator error (this is the largest single cause of bother in my workshop)
                    • The material
                    I suggest the steel may be at fault. Bog-standard mild-steel is a bit sticky and prone to tear. It machines OK, rather than well, a slightly awkward cuss! EN1A or EN1A-Pb (Leaded EN1A) are much easier to machine, if not using a 'free-cutting' steel, order some. Beware scrap – steels and other alloys are carefully specified to provide the particular properties needed in manufacturing. Many of them are difficult to machine. I'm afraid steel-makers don't consider the needs of hobbyists at all. An unlucky choice of scrap will baffle a beginner, you can guess how I know!
                    John Rutzen
                      @johnrutzen76569
                      I always climb mill the last thou or two, it produces a much better finish.
                      #633402
                      Martin Connelly
                        Looking back at my post the line that reads The chip thickness will be 3mm / 60mm/s­ = 0.05mm should have 3mm / 60 cuts/min.
                        Martin C
                        Edited By Martin Connelly on 14/02/2023 11:49:22
                        #633411
                        Baz
                          @baz89810
                          Don’t see any mention of how sharp the cutters are, if they are carbide or HSS, a decent brand or cheap rubbish ones also the OP says he is using the correct rpm for cutter size, where is this information gleaned from, big difference between model making feeds and speeds and those that are used in industry, how true is the cutter running, exactly how rippled is the surface, maybe a photo will assist us, maybe it’s just a standard finish from the side of a cutter, how experienced is the OP,
                          #633817
                          samuel heywood
                            @samuelheywood23031
                            OP can correct me if i've got him wrong but i believe he is talking about the machining marks~ rather than being straight vertical lines, they are rippled vertical lines.
                            Now i did fix this, but still can't remember how.
                            When i say fixed, i guess i mean it went from being VERY noticeable to having to look quite closely to see the effect.
                            Would tool run out cause this? Though i doubt I could have fixed that issue.
