Electric motor reassembly
Home › Forums › Workshop Tools and Tooling › Electric motor reassembly
  • #18959
    Maurice Cox 1
      @mauricecox1
      #357899
      Maurice Cox 1
        @mauricecox1
        I have just dismantled the motor from my lathe to clean it out, as I thought a piece of swarf may have entered the casing. There are enough slots and openings! As I removed the cover with the start switch on it, two wavy spring washers about 1 1/2" diameter fell out. There are none the other end. The housings look identical, as are the bearings. One at each end makes more sense to me. Has my motor been wrongly assembled for all these years please?
        Maurice
        #357901
        Brian Sweeting 2
          @briansweeting2
          Preloading the bearings perhaps?
          #357902
          David Jupp
            @davidjupp51506
            It is probably correct. One bearing housing should be a tighter fit, whilst the other allows some axial movement to handle thermal expansion – the wavy washers will go in the 'floating' housing.
            #357904
            mgnbuk
              @mgnbuk
              The wave washers are to provide a small axial preload on the bearings to ensure that they roll & don't skid if the motor is run unloaded. I would put them back as they were, as they were most likely positioned as the maker intended.
              Nigel B
              #357909
              Maurice Cox 1
                @mauricecox1
                Fair enough. Thanks a lot for you help.
                Maurice
