Early Myford Super-7B – Metric Conversion??
Home › Forums › Workshop Tools and Tooling › Early Myford Super-7B – Metric Conversion??
Viewing 25 posts - 1 through 25 (of 26 total)
  • #734513
    flatline
      @flatline
      I recently purchased a ‘Super-7B’, The Serial # is: SK45** (a 1955 machine,I believe), and the quick-change gearbox is QC16**.
      I am trying to establish if the Metric Kit from Myford will fit this gearbox. Myford say that it will, which I believe – however, I have heard that these early gearboxes ran at 50% of the speed that the later gearboxes fitted with hardened gears ran at – does anyone know if this is true??
      I found this snippet during my search for information:
      “The first quick-change gearbox became available in 1955, the gearbox used soft gears and the leadscrew drive was on the righthand side of the gearbox. In 1956, hardened gears were fitted to the gearbox.
      December 1956, the gearbox design was completely revised and, from gearbox No. QC2501, the leadscrew passed through the gearbox and the drive was taken form the lefthand side.”
      Could this be an indication that perhaps these early gearboxes may also have operated at a different speed?? Someone posted on-line to this affect, but I cannot find any further information.
      My guess is that the Metric Kit quadrant & tumbler gears, etc. may fit, but that they will not produce metric thread cuts due to the differing operating speed(s)??
      Can anyone cast any light in this??
      Your help greatly appreciated, many thanks
      #734514
      bernard towers
        @bernardtowers37738
        I believe there has been a recent discussion on this forum about this very thing
        #734517
        flatline
          @flatline
          ah, ok – I can’t seem to find it…
          #734533
          Hopper
            @hopper
            I think the thread you want is the recent “Boxford aud Metric Gears” thread. Much discussion there of various ways to convert your imperial British lathe to metric screwcutting using various translation gears. Both have 8 TPI leadscrews so the principles apply to both.
            In it, Michael Gilligan helpfully supplied this link to a previous thread about using a 33 and 34 tooth gears to do metric conversion on a Myford. Much cheaper than the Myford kit! The link is https://www.model-engineer.co.uk/forums/topic/thread-cutting-2/#post-204892
            As to the earlier gearbox running at half speed of the later box, I would expect you could work around that by either fitting a double sized gear on the lathe spindle or a half sized gear on the gearbox input. Or by selecting 2mm pitch on the gearbox in order to cut a 1mm thread etc. It all depends on whether Myford changed the gearbox speed internally or via the gear train between the lathe spindle and the gearbox.
            But I have no great experience with gearbox Myfords (mine is change wheels only) so can’t say. Others will know, I am sure. And the exploded diagrams on the Myford site might help.
            #734595
            Brian Wood
              @brianwood45127
              I might be able to help here. The early gearboxes were fed by a 12 tooth driver; the gearbox itself had a small side outrigger box on the tailstock side that provided the reduction drive to the leadscrew.
              Those that were build later than serial no 2501, incorporating the through leadscrew, have a 1:2 reduction gear (26 drives 52) slim gear set just behind the gearbox proper. The 26T gear is hardened, the other equally slim gear is not. The arrangement for this gearbox and its working is shown and described in my book. At the time of writing that I was not aware of the difference in the drive arrangements in the early gearbox
              Last but by no means least, the later gearbox is driven by the the more familiar 24T driver, hence the need for the reduction gears.
              There was a long post exchange in the old forum pages started by Simon Williams who has the earlier machine. He was struggling to understand why he was getting half pitch threads using my book as the guide.
              I hope this brief description helps
              #734601
                Trying to do my bit for the common good …
                I think this is the Topic to which Brian refers:https://www.model-engineer.co.uk/forums/topic/help-with-myford-metric-gear-setup/
                Please correct me if I’m wrong, Brian
                #734603
                Brian Wood
                  @brianwood45127
                  Well done Michael, I don’t think I would have been able to retrieve that.
                  It is that conversation and shows the side gearbox well, I didn’t trawl through it all as I have things I must do today, much as I would like to see where this goes now.
                  #734607
                    Simon Williams 3
                      @simonwilliams3
                      Hi all, thanks Brian for the acknowledgement.  There is the whole nine yards on this topic buried in the old archive but I’m not sure I know how to access it.
                      For the time being the salient points are that yes there is an older version of the Myford manufactured quick change gearbox which runs at half the speed of the later one.  This means that the Myford metric kit will fit onto the banjo but won’t give the results you’re expecting.  The banjo in question is not the same one as the normal one driving the QCGB with fixed centres, you have to take that off and substitute the slotted one which comes with the metric kit.
                      To make matters worse there are two metric kits; both of them are intended to operate the newer double speed QCGB not the older half speed GB.  I believe the associated banjo is common to both kits but one kit has one less gear than the other, though it seems to achieve the same results.
                      The older gearbox uses a 39/12 all in one compound gear as the input to the gear train whereas the newer one uses a 30/24 gear pair, the 24 gear is removeable and can be changed to other counts to give other TPI figures outside the published table.  Brian has written the definitive analysis of this and I recommend his book “Gearing of Lathes for Screw Cutting” which gives chapter and verse, albeit only in respect of the (much commoner) newer version of the QCGB.
                      I think it would be helpful if we could find the two or three threads where we have rehearsed this subject in the old forum.  I’m out for the afternoon but I’ll see if I can find the details this evening.
                      Last but not least if it is the older QCGB you have don’t go buying the 33 and 34 tooth change wheels which permit metric threads to be cut with the QCGB but only with the later version. They don’t fit on the banjo of the older gearbox so you can’t use them.   If we can establish beyond all doubt that the GB is the old one I have a set of the 30/17 and the 29/16 gears which are the correct metric adaptors in stock you can have for a moderate contribution to charity.  I’m not sure you can ping me a PM any longer, but we’ll fathom something out via the classifieds.
                      Hopefully more will follow later.  In the meanwhile the answer to the original question is that you can buy and fit the Myford metric conversion kit, but it won’t give the results you are expecting.
                      Rgds Simon
                      #734635
                      Simon Williams 3
                        @simonwilliams3
                        Sorry all, beware of the unrequited tyo.  I refer to a 39/12 compound gear – that’s nonsense.  It should read 30/12 compound gear.
                        Apologies Simon
                        #734639
                        flatline
                          @flatline
                          Simon,
                          I have sent you a PM, hopefully it will have arrived with you.
                          Rich D.
                          aka Flatine
                          #734645
                          Simon Williams 3
                            @simonwilliams3
                            Here’s one of the threads from the archive:
                            https://www.model-engineer.co.uk/forums/topic/myford-super-7-screw-cutting-gears-metric/page/3/
                            I think we need the other pages as well from the same thread.  How do I pick those up?
                            #734677
                            peak4
                              @peak4
                              #734700
                              Brian Wood
                                @brianwood45127
                                Peak4,
                                Sorry to point this out but Simon above has said that these gears will only work with the later versions of the gearbox. He has made the necessary gear pairs that suit the early gearbox, having done the work developing them in association with the late John Stevenson
                                I remember the exchanges back and forth to resolve the impossible 1/2 gear that is what the calculations suggested.
                                Regards  Brian
                                Edit  Michael G has very helpfully resurrected all that old thread material from the original forum some way back in this thread
                                #734739
                                peak4
                                  @peak4
                                  On Brian Wood Said:
                                  Peak4,
                                  Regards  Brian
                                  Appreciate that Brian, but something odd has happened with my post(s). I put up links to several previous threads, at an earlier time, which have vanished from the post above.
                                  I edited it a couple of times, added some words and links, which have now all vanished.
                                  My intention was to pull several Myford gearbox metric thread posts all onto this topic, so if someone went looking again in the future, with different queries, they might come across them all in one place.
                                  My bookmarks were to the old forum posts, so took a while to resolve the new locations via archive.org; no idea where it all went.
                                  Bill
                                  #734762
                                  Brian Wood
                                    @brianwood45127
                                    Hello Bill,
                                    Michael G was able to salvage the Simon Williams thread from the old forum, maybe he can assist you with finding what seems to be missing.
                                    In the meantime, trying to gather all the exchanges on this topic in the hope of making a definitive record is I think somewhat ambitious, laudable as it certainly is. Then there is the difficult question as to where and it what form do you keep it for access by others yet to ask these questions.
                                    Knotty issues that make the brain hurt!
                                    Regards   Brian
                                    #734764
                                    flatline
                                      @flatline
                                      Brian – agreed, I have noticed on forums elsewhere that a ‘stickie’ can be created, which permanantly pins the thread (with a suitable title) to the top of the relevant page, perhaps ‘Admin’ can help here??
                                      Rich D.
                                      #734765
                                      JA
                                        @ja
                                        I cannot really give any advice on this. I have a Myford metric conversion kit and have not used it. When ever I have wanted to use it I have been put off by the time required to fit it. I may be wrong but it seems difficult if one is swapping between Imperial and Metric.
                                        The John Stevenson 33t/34t set up does not fit my lathe (a late Big Bore Super 7). The bottom wall of the casing gets in the way.
                                        JA
                                        #734767
                                        Frances IoM
                                          @francesiom58905
                                          Re creating a ‘definitive’ thread on any subject on the web or even on this site is a forlorn hope – many pages and even sites disappear within months – the archive built up on the precursor to this site was wantonly thrown away – even now I find many images etc appear as 404 errors.
                                          #734771
                                          Brian Wood
                                            @brianwood45127
                                            Is it not possible to ease that restriction in some way? I don’t know the Big Bore 7 so can’t quite see where the trouble lies.
                                            I think you might find the results worth the effort.
                                            Regards   Brian
                                            #734773
                                              Bill
                                              Further to Brian’s post:
                                              I make no ‘pledge’ [what a topical word!] of success … but I’m happy to work with you on this, to the extent that I am able.
                                              If you send me your archived bookmarks on the subject, let’s see whether another pair of eyes is any help.
                                              John Haine
                                                @johnhaine32865
                                                I don’t think anyone has mentioned the possibility of fitting an ELS?  Then the problem goes away.
                                                #734819
                                                JA
                                                  @ja
                                                  Fitting 33t/34t gears to a Big Bore Myford, I should provide a photograph of the problem but I lack the time and it is not on my list of priorities or even problems that may occur in the foreseeable future.
                                                  One day?
                                                  JA
                                                  (edit) Fitting an ELS. I am interested in the idea but I no longer have the time.
                                                  #734821
                                                  Hopper
                                                    @hopper
                                                    Does anyone sell an easy-to-install ELS kit for Myfords, for the complete non-electronic numpty?
                                                    #734905
                                                    peak4
                                                      @peak4
                                                      On Michael Gilligan Said:
                                                      Bill
                                                      Cheers, but I think I resolved the links I had bookmarked, some of which have now appeared on this thread anyway.
                                                      The others are probably not that relevant, though they themselves contained old links which are, but have now been updated here.
                                                      Essentially I just used archive.org on the old link, to see what actual thread it opened up, as it wasn’t always obvious from the title. I could then search for that thread on the new forum, either directly or via Google.
                                                      The difficulty is that when I click on an old link, the current forum auto forwards it to a 404 page, but the back button does not show the old link, pre-forwarding.
                                                      Hence needing to dive into the saved bookmarks folder.
                                                      It’s the vagaries of different browsers, I use opera, where I have the bookmarks stored, but there is no easy way to see the URL behind the bookmark title.
                                                      Backing up the Opera bookmarks folder (in HTML), and opening it in Pale Moon, allows me to, see & copy, the actual stored URL to plug into Archive.org.
                                                      Fiddly, but it works OK.
                                                      Bill
