Dropping 12v dc to 6v dc
Home › Forums › Help and Assistance! (Offered or Wanted) › Dropping 12v dc to 6v dc
  • This topic has 46 replies, 24 voices, and was last updated 30 May 2018 at 15:15 by duncan webster 1.
Viewing 25 posts - 1 through 25 (of 47 total)
  • #33207
    vintagengineer
      @vintagengineer
      #355288
      vintagengineer
        @vintagengineer
        I need to drop 12v dc to 6v dc on a vintage car. It's to run a Bosch Mag Starter coil ignition system. It will be quite high amps. Any ideas please?
        #355290
        Dave Halford
          @davehalford22513
          #355292
          Brian Rutherford
            @brianrutherford79058
            Google ballast resistor
            #355300
            Speedy Builder5
              @speedybuilder5
              Dave H, I can't see a 12 to 6volt dropper on that site/link Am I missing something or did you mean buy 2 x 6volt batteries ?
              BobH
              #355304
                A Step Down Buck Converter might do the job, unlike a Ballast Resistor they're efficient and the output voltage is stabilised. This example is 18W (3A) – beefier versions available.
                #355307
                Grindstone Cowboy
                  @grindstonecowboy
                  Posted by Speedy Builder5 on 25/05/2018 17:49:40:
                  BobH
                  Possibly Dave H is suggesting using one of their 12V batteries and tapping off the exposed connector to get 6V? But I'm not fully sure whether vintageengineer needs 12 AND 6 volts?
                  #355308
                  vintagengineer
                    @vintagengineer
                    The car runs a 12v system but has a 6v Bosch Starting coil.So I need a way of dropping 12v to 6v but quite high amps.
                    #355314
                    Anonymous
                      Before we can suggest a solution the problem needs to be properly specified. For a start how many amps? 10? 100? How stable does the 6V need to be, ie, what range can it vary over? A fraction of a volt or would a couple of volts be fine? Can the 6V unit withstand 12V if it isn't drawing any current, or momentarily, or will it go bang?
                      #355315
                        I assumed 'Starting Coil' to mean 'Ignition Coil' in which case 5 Amps should be plenty for a 12v coil. I suppose a 6V coil might need proportionally more amps to get the same sized spark.
                        But if Vintage means 'Starting Motor' I guess 60A plus would be needed to turn a small car engine.
                        #355317
                        not done it yet
                          @notdoneityet
                          12 volt ignition coils only take 5 amps max as a resistive component within a contact breaker system. As soon as the engine starts that will be reduced considerably – dwell angle and inductive nature of the coil will both reduce the current, the first during thewhole speed range and the second more so at high rpm.
                          The capacitive discharge system I made, back in the 70s could have used a 1A meter to virtually read rpm, IIRC.
                          #355319
                          vintagengineer
                            @vintagengineer
                            No, it's a special Mag starter coil. It's a complicated ignition trembler coil and combined switch that starts the engine then you switch over to the mag to run the engine. The engine doesn't need a starter motor to start the engine.
                            Posted by SillyOldDuffer on 25/05/2018 19:58:57:
                            #355343
                            Dave Halford
                              @davehalford22513
                              Sorry,
                              Posted by Rob Rimmer on 25/05/2018 18:27:36:
                              BobH
                              Sorry, I was suggesting centre tapping the 12V battery, it's the simplest system, but possibly a bit 'old school'. For me Vintage and electronics don't mix
                              #355346
                              Grindstone Cowboy
                                @grindstonecowboy
                                +1 on that, Dave – I think it's the simplest and best way to get the current required.
                                #355351
                                Harry Wilkes
                                  @harrywilkes58467
                                  Some years back to aid cold starting quite a few cars had 6v coils with a resistor in series but when starting the engine for a few seconds the resistor was bye passed this proved very useful in the really cold winter's
                                  H
                                  Edited By Harry Wilkes on 25/05/2018 21:33:07
                                  #355358
                                  Muzzer
                                    @muzzer
                                    Posted by Dave Halford on 25/05/2018 21:11:28:
                                    Sorry,
                                    BobH
                                    You might call it old school and simple but it's also not a brilliant idea. There's no means for the lower 3 cells to recharge unless you grossly overcharge (dry out / gas) the top 3 cells. It'll work for a short while, then you are likely to find you've buggered the battery.
                                    If you want to do it properly, you'd want to drop the 12V down to 6V (actually 14V down to 7V) using a converter, perhaps like the ones mentioned above. You can use a 12V battery with a centre tap this way without causing a charge imbalance.
                                    Murray
                                    #355430
                                    J Hancock
                                      @jhancock95746
                                      One wrong move and it's " Goodbye, 6V system".
                                      Try to use a 6V battery to feed it and be worry free.
                                      #355448
                                      Ron Laden
                                        @ronladen17547
                                        Would it be possible to fit 2 x 6 volt batteries wired in series to feed the 12 system and take the 6 volt ignition side off both the batteries but in parallel…..hmmm dont know..? that was straight off the top of my head.
                                        Ron
                                        #355450
                                        Roger Hart
                                          @rogerhart88496
                                          I would respectfully suggest this job is more difficult than it looks. To swing the 6 volt 'motor' requires high amperes of the order 200 to 300 and there will be some vile current waveforms and spikes as it turns. Really only a 6 volt battery can handle that and a fairly meaty one at that. Then comes the charging of the 6 volt battery from 12 volts. A simple dropper resistor is probably not so good here. Something is needed to regulate the 6 volt battery charge. Possibly the mag starter has the necessary to do that, maybe not.
                                          #355463
                                          vintagengineer
                                            @vintagengineer
                                            There is no motor. It's a Bosch Dual Ignition Switch which uses a 6v trembler coil to start the engine. The engine is turned by hand to TDC then you switch on the ignition and the engine fires up.
                                            Posted by Roger Hart on 26/05/2018 14:16:32:
                                            #355464
                                            Russell Eberhardt
                                              @russelleberhardt48058
                                              I presume that you have the system whereby the engine is started using a trembler coil and when running it is switched over to magneto. That type of system was often used with a non rechargeable dry battery as it was only used on the trembler coil for a short time. The battery was changed when it no longer produced enough power for the trembler coil. You could perhaps use a second small sealed lead acid 6 V battery and charge it when necessary. If you are not too worried about keeping things in period you could float charge it off the 12 V system with a small switching regulator.
                                              Russell
                                              #355471
                                              Clive Steer
                                                @clivesteer55943
                                                The starting system described by Vintageengineer using a magneto and trembler coil was used for starting large capacity but slow speed petrol engines such as large aircraft radial types. The trembler coil is similar to an electric bell/buzzer with coil, contact and battery in series. One side of the coil is common to the ground of the magneto and the other to the "live" contact of the magneto. The engine is primed with fuel/air called sucking in by turning the propeller over several times and then one cylinder is brought just past full compression where the magneto contact will be open. The guy turning the prop will stand clear and say to the pilot "contact" whereby he connects the battery to the trembler system. As it buzzes the large voltage spikes produced by the trembler coil will get boosted by the magneto producing a stream of sparks at the plug and the engine will chuff into life.
                                                The modern method for aircraft is to have an impulse mechanism on one magneto that flips the magneto as it gets to TDC to produce a good spark. The trembler system is in effect an inductive version of capacitor discharge ignition.
                                                To use a 6V trembler coil system on a 12V battery may only need a larger dropper resistor as the trembler is only used for a short time.
                                                #355478
                                                  A dropper resistor is the simple and reliable way, you just need a reasonable idea of the coil's working amperage, divide six by the current in amps and select the nearest wirewound resistor.
                                                  For example, if it takes 0.5 amps, use 6/0.5 = 12 ohms. A 10 watt 12R resistor should be fine.
                                                  #355481
                                                    Now the clarification has confirmed my original assumption, I suggest again a buck converter like the one I linked to on Amazon; they sell a 10A unit if 3A is considered too small.
                                                    Comments on other ways of doing it:
                                                    • To use a separate 6v battery you have to find somewhere in the car to put it, install wiring to the trembler, and also arrange for the non-standard battery to be kept charged. As the duty cycle is low, a leisure battery should be used rather than an ordinary vehicle type. I suggest the combination is complicated and costly.
                                                    • Tapping 6v off an existing 12v battery requires the connections between cells to be exposed and most modern batteries are sealed. But as Muzzer explains, the arrangement is also thoroughly bad practice because it's going to damage the battery! Get you home bodge yes, permanent solution no.
                                                    • Ballast resistors may not be straightforward. As we don't know how much current the trembler draws we can't calculate either the electrical resistance required, or how much heat it will have to dissipate. I suggested a 5A peak current requirement and NDIY's figure of about 1A continuous seems reasonable. The numbers help a little – a resistor between 10 and 30w, and 1 and 6 ohms. More worrying to me is how well a 6V trembler will cope with having 12v whacked into it! At switch-on, the full 12v is applied via the resistor to the trembler. That causes extra stress on the low voltage side and outputs an extra high voltage pulse that risks puncturing the coils insulation, perhaps burning the trembler out after a few months. Ignition coils are often deliberately rated to run with a ballast resistor. I wouldn't assume the same is true of a trembler system – I've no idea how electrically robust they are. Can anyone comment?
                                                    Buck converters come as simple 4 wire modules available inexpensively for automotive application. You can view them as being a clever resistor where you don't have to calculate anything or worry much about overheating. Quite simple to install – two wires connect to the 12V system and 6V pops out on the other pair. Worth a try I feel: even the 10A unit on Amazon costs less than a tenner.
                                                    Edit : my typist is extremely careless.
                                                    Edited By SillyOldDuffer on 26/05/2018 18:41:34
                                                    #355506
                                                      A trembler is basically a buzzer/shock coil, so not very choosy about voltage at all.
