Drilling brass
Drilling brass
Home › Forums › Beginners questions › Drilling brass
  • #364972
    Roger Hulett
      @rogerhulett83124
      I need to drill three equidistant holes in a brass tube. I presume that I would centre the tube on my lathe and then scribe a line through which the hole centres would go, but how do I position those holes accurately ?.
      Having done that I need to cut a triangular hole in the tube (not on the same scribe line), how do I do that ?.
      Thankyou.
      #9278
      Roger Hulett
        @rogerhulett83124
        #364980
        Speedy Builder5
          @speedybuilder5
          What do you call accurately? Most of us use a centre punch (without deforming the tube) and pre drill with a centre drill. You don't say how big the holes are, or diameter / thickness of the tube etc. A drawing always helps. Triangular holes start off from a round hole, and made triangular by a triangular file. You don't say what machines you have available, so I don't think we can help too much on the limited information. Perhaps give us a bit more info for a more precise answer.
          BobH
          #364982
            If they are equidistance around the tube an easy way to divide it into 3 is to hold in the 3-jaw chuck. Then find a block of metal or wood that will roughly fit between lathe bed and one of the chuck jaws, use that as a stop to hold a jaw against, mark position and then do the same with the other two jaws against the block.
            If you blue the tube with a marker pen then lightly dragging a tool in the tool post over the surface will mark the positions.
            Depending on the triangle a hole drilled first than a triangular file works well.
            #364987
            pgk pgk
              @pgkpgk17461
              Also if you set a pair of dividers to the width of the radius you can walk it around the circumference to divide into 6. Or wrap a pice of paper round the tube and measure/mark and transfer from that.
              pgk
              #364996
              Roger Hulett
                @rogerhulett83124
                Excellent, thankyou.. I took the easy route. A piece of paper, worked very well. Now for the triangle which I am not so confident with, however will persevere slowly. Thankyou all.
