Dial Gauge Advice
Dial Gauge Advice
Home Forums Beginners questions Dial Gauge Advice
Viewing 21 posts - 26 through 46 (of 46 total)
  • #378513
    Cornish Jack
      @cornishjack
      Mick B1 – quite so. I have two such items – one on a 3MT arbour with an adjustable cross-slide, tailor boxed , by Pratt and Whitney and another on a 2 morse. If I was more competent and did more in the shed, they would probably be used more!
      rgds
      Bill
      Brian Whelan
        @brianwhelan75518
        Wow – can't believe the response. Many many thanks to every-one. Food for thought indeed.
        I'll re- read the posts after tea.
        ATB
        #378526
          Posted by Howard Lewis on 31/10/2018 17:17:19:
          Because of the variations introduced by the angles of the probe end of the finger clock, they are not really suitable for absolute measurement. Mine is used almost exclusively for centering work (OD or ID) in a 4 jaw chuck. Finger clocks (Sometimes referred to as Verdict clocks, after one of their makers) …
          I agree, Howard : They are 'indicators'
          That said; it's worth noting that the "pear-shaped" tip, supplied by Verdict, confers much better linearity than the common ball-ended probe.
          http://mjallen.co.uk/application/files/4614/7686/2624/Styli.pdf
          Edited By Michael Gilligan on 31/10/2018 18:11:52
          #378579
          Zan
            @zan
            I use my plunger type once a decade, the lever type almost every machining session it works in both directions and is invaluable on Miller, and lathe in bores and trimming . Do get a micro adjusting stand to go with it. There were some at the Foss as a complete set for about£26.00
            #378593
            not done it yet
              @notdoneityet
              Zan,
              Have you already used it this decade? smiley
              #378599
              Brian Whelan
                @brianwhelan75518
                Thanks for all the comments and advice. Didn't realise there would be so many variable opinions on this. I was aware of the dial gauge but posted the question after watching a video on YT where the chap used a finger type gaude nearly all the time. Also I did not realise about the base and stand (I thought they would all be the same).
                So in a nutshell – I am extremely grateful for all the input you have provided, (Its a big nutshell).
                Many thanks
                #378605
                  Posted by Michael Gilligan on 31/10/2018 18:09:04:
                  … it's worth noting that the "pear-shaped" tip, supplied by Verdict, confers much better linearity than the common ball-ended probe.
                  blush Just noticed that ega had already mentioned this on page1 blush
                  #378606
                  Mick B1
                    @mickb1
                    Posted by Brian Whelan on 01/11/2018 08:21:46:
                    Many thanks
                    Model Engineering itself is an idiosyncratic hobby.
                    You can expect big differences in the way its hobbyists have learned to resolve the problems they come across.
                    For example, I use my plunger and finger clocks about equally, but I mount them on a bit of flat bar in the toolpost, or in the lathe or drill chucks.
                    I only wish I had a magnetic base about once a decade… laugh
                    #378608
                    Martin Johnson 1
                      @martinjohnson1
                      I only have a plunger type, and I would only buy a quality make. I have been at this game about 50 years now, and 40 years as a chartered engineer.
                      I have always found the very limited travel of the lever type to be a complete pain – very good for certain types of work as noted above, though.
                      HOWEVER I have a little pivoting lever attachment I made up years ago that fits around the stem of my plunger type dial gauge, which gives it most of the functionality of the lever type. Except for getting into the really tightest of tight spots. There was a design for such an attachment in the early issues of Model Engineers Workshop – sorry I don't have the reference any more.
                      Martin
                      #378609
                      Vic
                        @vic
                        If you decide to get a DTI have a look here.
                        The Swiss made ones are reckoned to be the best.
                        #378615
                          Posted by Martin Johnson 1 on 01/11/2018 09:04:31:
                          MEW issue 1 [Summer 1990], pp14-17
                          Attachments for Dial Test Indicators : R.J. Loader
                          ega
                            @ega
                            Posted by Michael Gilligan on 01/11/2018 08:49:00:
                            I was glad to get confirmation of this point and, having followed up your helpful link, I see that I should have said eliminate rather than mitigate ie Verdict claim accuracy within the angular limit given. Their diagram is rather small and they don't give the underlying maths; I was hoping that some of our more scientific members – you, perhaps – would weigh in with the proof.
                            Andrew Johnston:
                            I have just installed a pear-shaped collet tray on the lathe; so far it hasn't gone belly up!
                            #378622
                              Posted by ega on 01/11/2018 09:38:17:
                              Thankfully, I don't need to clutter the forum with my attempt at a proof
                              It's very well detailed in Verdict's patent:
                              https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=3161963A&KC=A&FT=D&ND=3&date=19641222&DB=EPODOC&locale=en_EP
                              Edited By Michael Gilligan on 01/11/2018 09:55:21
                              #378632
                              Oldiron
                                @oldiron
                                Posted by Mick B1 on 31/10/2018 14:35:03:
                                True, but Baty at least make, or used to, a bellcrank-type finger-lever that clamps onto the plunger sleeve and allows the gauge to work in that situation. Still a bit of a faff compared to a finger-type gauge, though.
                                I have one dial indicator that is permanently fitted with cranked finger. I find it very useful & easy to read without putting on the optivisor.
                                I got a box full of these in an auction lot and sold many on Ebay. Still have a few pieces left in that box somewhere I think.
                                To the original OP, you will not go wrong with both types as they have their own separate uses
                                regards
                                Edited By Oldiron on 01/11/2018 10:43:34
                                #378636
                                ega
                                  @ega
                                  Michael Gilligan:
                                  Thank you. The answer seems to be in the last paragraph of the patent (which I assume has now expired).
                                  I suppose another "proof" of a sort would be to compare the readings from the same setup using both spherical and pear-shaped styli.
                                  #378690
                                  Howard Lewis
                                    @howardlewis46836
                                    Lever adaptors to allow a Plunger clock to be used in a bore were made commercially. May still be, if we could find the right place to look.
                                    I have a secondhand John Bull Plunger clock with one of these among its accessories, although very rarely used. The Verdict finger clock is the device normally used, for centering the bore or the OD. once it is reasonably near by eye.
                                    #378702
                                    Oldiron
                                      @oldiron
                                      Posted by Howard Lewis on 01/11/2018 15:14:54:
                                      Try here:- **LINK** There are probably others available.
                                      regards
                                      #378717
                                      Emgee
                                        @emgee
                                        If anyone wants to make their own conversion to use a plunger type clock in a bore there was an article in ME many years ago providing full details. I made mine ages ago to check bores were parallel when bored.
                                        Perhaps someone with a full index could check for the issue number.
                                        Emgee
                                        #378723
                                        Rod Ashton
                                          @rodashton53132
                                          Ref Oldiron Link, – It is worth noting that the linked site has a dimensioned drawing and 3d CAD files for download.
                                          #378729
                                          Emgee
                                            @emgee
                                            Well spotted Rod, I didn't scroll down when I noticed the difference to the attachment I made, that was to enable measurements to be taken in the bore or slot, I will look it up and post a picture.
                                            Emgee
                                            #378731
                                            fishy-steve
                                              @fishy-steve
                                              How about Harold Halls site?
                                              Steve.
