DC motor controler ?
Home › Forums › Manual machine tools › DC motor controler ?
  • #13176
    Anonymous
      #346870
      Anonymous
        This post has been removed at the author’s request.
        #346871
        Muzzer
          @muzzer
          Seems to be a controller for a single phase induction (AC) motor. Not unusual for the pen pushers at RS to describe something they don't have a clue about and get it completely wrong.
          Short answer – no.
          Murray
          And all the DKM motors listed on the RS site are described as "reversible AC induction motor" and are truly piddle power. You'd struggle to even turn a machine with them, so presumably the controller is also miniscule. Not the most informative datasheet.
          Edited By Muzzer on 20/03/2018 18:09:45
          #346876
          Anonymous
            #346881
            norman royds 2
              @normanroyds2
              The one I am using is cheetah SME 2HP input 110 /220 240 ac 16 AMPS 50/60hz output ;0.90/0.180v dc 11AMPS so it give somewhere to start carl hope this some help regards norm
              #346883
              Anonymous
                #346885
                oldvelo
                  @oldvelo
                  Hi
                  More info on the end use would be useful. Assumption is mother of all misunderstanding
                  X1 Mill ?
                  No connection with KB Electronics on my part just satisfied user
                  Start looking here
                  Expensive but very reliable
                  More here using one from this source using one on a band saw.
                  John Haine
                    @johnhaine32865
                    I also use a KB Electronics one on my Novamill spindle.  It works very well, have never had anything blow except a fuse when the mill decided to execute a "G0" rather than "G1" feed into the material, stakllked the motor and broke the cutter.
                    Edited By John Haine on 20/03/2018 20:04:06
                    #346892
                    Anonymous
                      #347035
                      oldvelo
                        @oldvelo
                        Hi Carl
                        Here is another link to a unit that may be useful. RS are way off with there description it is NOT AC to DC at all is is for a low power AC motor ( Extractor Fan)??? perhaps
                        Set up seems to be straight forward enough with the controller to match the motor.
                        Eric
                        Edited By oldvelo on 22/03/2018 02:35:32
                        #347384
                        Anonymous
                          #347392
                          Michael Cox 1
                            @michaelcox1
                            Hi Carl,
                            Here is a motor/ controller combination similar to the one posted by oldvelo. This one is rated for 240 volts and available in the UK.
                            https://www.aimtools.co.uk/collections/spare-parts/products/katsu-550w-power-head-attachment-for-mini-lathe-machine-165013-and-165012
                            #347393
                            John Rudd
                              @johnrudd16576
                              Carl,
                              As the motor came from a Sieg mill, why not use the intended controller..? The XMT2315/230V.
                              Available from a Sieg dealer near you….Arceurotrade….
                              That way it minimises any setup issues with min/max speed settings and any overload/over current issues.
                              Edited By John Rudd on 24/03/2018 17:01:24
                              #347399
                              Anonymous
                                #347402
                                Anonymous
                                  #347409
                                  Anonymous
                                    #347432
                                    John Rudd
                                      @johnrudd16576
                                      I'm sure we can get you up and running…even if we have to do a point to point, step by step method of wiring up….
                                      But I stress the choice is yours……!
                                      #347909
                                      Anonymous
