Dails Caliper has a mystery component in box?
Home › Forums › Beginners questions › Dails Caliper has a mystery component in box?
  • #425017
    Chris TickTock
      @christicktock
      Hi, i have bought a used dial caliper but it has a copper looking thing about 2b inches long thin at one end with a sphere to hold it at the other, i would guess its for calibration but does anyone know for sure what it is for and how it is used.
      regards
      Chris
      Can anyone help guide me how to upload a picture with a post/
      #9805
      Chris TickTock
        @christicktock
        #425018
        Brian G
          @briang
          Hi Chris
          If you click on the "Albums" link at the top you can create a new album and upload your image. Then to put it in a post you click on the camera icon (top row of the box you type your message in) and select the image from your album.
          Neil put full instructions here **LINK**
          Edit:  Is the box fitted to take the additional item?  If not, could it be part of a wiggler like this?
          Edited By Brian G on 19/08/2019 13:54:23
          #425019
          old mart
            @oldmart
            Dial calipers have a rack which meshes with a gear that drives the pointer. Sometimes the gears jump a tooth or more, resulting in the pointer not reading zero when the jaws are shut. I am guessing, here, but the tool may be for tipping the spring loaded gear out of mesh with the rack, to get the pointer reset. I had a Tesa dial caliper, but that was 40 years ago, and my memory is not great.
            Somebody will be able to post some photos showing exactly how its done.
            #425034
            Chris TickTock
              @christicktock
              Posted by Brian G on 19/08/2019 13:51:13:
              Hi Chris
              Thanks guys appreciated.
              Chris
              #425043
              Mick B1
                @mickb1
                Posted by old mart on 19/08/2019 13:55:15:
                I thought the things must've stopped doing that since then, otherwise why are people still buying them?
                surprise
                #425053
                old mart
                  @oldmart
                  If a foreign body gets trapped in the rack, the pinion would be destroyed if there was no allowance made to spring load the pinion shaft. Outside of a clean room, shit happens.
                  #425162
                  David George 1
                    @davidgeorge1
                    Hi I have a dial caliper and in the box is a copper coloured strip which is used to adjust the dial if it jumps a tooth. You slide it between the rack and gear and then slide the carriage along a small amount and then pull out strip it may take a few tries to get it right.
                    David
                    #425173
                    old mart
                      @oldmart
                      That's exactly what I was trying to explain, David, thanks for the endorsement.
                      #425182
                        Posted by old mart on 20/08/2019 13:08:17:
                        Just one small caveat, if I may: The descriptions of the tool's purpose are fine, but it is always worth checking the rack and cleaning if appropriate. … Said foreign body can sometimes be stuck in place rather tenaciously
                        Chris TickTock
                          @christicktock
                          Thanks guys you have given me enough to work on.
                          Chris
                          #425203
                          old mart
                            @oldmart
                            This is the weakness of a design with exposed gears, you have to take care not to drop then in the dirt.
