Custom cross slide
Custom cross slide
Home › Forums › Manual machine tools › Custom cross slide
  • #12276
    Mr Moo
      @mrmoo
      #147484
      Mr Moo
        @mrmoo
        Evening All,
        I have access to an old but serviceable ZZM Sofia C8m lathe but no milling facility. I am looking for a cross slide with T slots. Either one already available or even a custom made one, as long as it is within reason pricewise.
        I have sketches with sizes if that would help with sourcing or pricing for a custom job.
        Any help gratefully received,
        TIA,
        Ben
        #147515
        roy entwistle
          @royentwistle24699
          Ben There have been milling slides advertised under the For Sale column
          Roy
          #147518
          Keith Long
            @keithlong89920
            Ben
            T slotted cross slides appear very regularly on EBay – mostly for Myfords of various flavours, but also other lathes. You will probably find it cheaper to explore that route rather than getting a custom slide made. You will need to try and get some dimensions for other lathes to compare to your machine though. An alternative that might work could be to make a "sub-table" or milling table to fit onto your existing cross slide. The easiest way to fit the table to your machine would probably be by drilling and tapping some suitable mounting holes in your cross slide to hold the sub-table, or if you don't want to drill, could you clamp a sub-table to your slide. The sub-table could be made from steel or aluminium plate with either built up T slots or holes drilled and tapped to suit the job that you want to hold. An advantage of the sub-table route is that it could be made by hand rather than machining and you could make tables with different hole/slot patterns to suit individual jobs.
            Just some thoughts on other possibilities.
            Keith
            #147523
            Robbo
              @robbo
              Ben,
              It might help if you were to post your sketches with measurements on an album on this website. Then you could put them in a post.
              Give us all a better idea of what is required, as I suspect few of us can imagine the lathe you mention.
              Assume from the name that it is made in Bulgaria.
              Phil
              Edited By Robbo on 20/03/2014 13:52:28
              #147549
              Mr Moo
                @mrmoo
                Thanks for the replies/suggestions. I'll draw up the dims I've got, all nice and neat.
                It is a Bulgarian lathe, approx. 12×20, original equipment for the vessel, so around 40 year old but still all good!
                The sub-table idea might be worth persuing…
                #147571
                Robbo
                  @robbo
                  With a 12" swing you've probably got plenty of room for a sub-table. I was thinking of Myford sized, but probably a bit small for your lathe, unless you bolt the whole Myford cross-slide on top of your cross-slide.
                  Phil
                  #147586
                    Ben,
                    If you are happy with the idea of a sub-table; have a look at the C6 item on this page from Arc … it looks very adaptable.
                    Mr Moo
                      @mrmoo
                      Thank you all for the ideas and pointers. I am continuing to look and gather information
                      #148192
                      Michael Cox 1
                        @michaelcox1
                        You could fabricate one using the techniques proposed by Martin Cleeve many moons ago. I made a tee-slot cross-slide for my mini-lathe using this technique,see:
                        http://mikesworkshop.weebly.com/tee-slot-cross-slide.html
                        #148196
                        Bazyle
                          @bazyle
                          T slots are never where you want them Just yesterday I was debating whether to bolt down a plain plate over my T-slots to more easily mount a rear tool post.
                          #148210
                          MICHAEL WILLIAMS
                            @michaelwilliams41215
                            Which is best for general purposes – T slots along the length or cross wise ?
                            Michael Williams .
                            #148380
                            Mr Moo
                              @mrmoo
                              That's a very good question Michael!
                              #148381
                              Keith Long
                                @keithlong89920
                                A good argument for going down the sub-table route, you can have both or a mixture using different sub-tables.
                                Keith
                                #148384
                                  Posted by Keith Long on 29/03/2014 12:02:35:
                                  Well-said, Keith.
                                  KWIL
                                    @kwil
                                    Photo lower front right shows a custom made milling cross slide for a Myford S7 with T slots both ways.
                                    #166667
                                    John Burridge
                                      @johnburridge26484
                                      I wonder if you managed to fine a Tee slotted cross slide you could try John Ward on No 01282-869262 he has a web page at http://WWW.latheparts.co.uk he has made replacement parts and accessories for old and obsolete lathes and millers for years at reasonable prices he also makes most types of gears and accessories for laths and mills as well.(not a advert just a satified customer).
                                      #166696
                                      thomas oliver 2
                                        @thomasoliver2
                                        I support the last post for John Ward. I bought a slotted crsoss-slide from him some years ago and it was very well made and half the price of another well known firm.
                                        #166702
                                          Chew one out from a lump of cast iron
