crank shaft
crank shaft
Home › Forums › Beginners questions › crank shaft
  • #346945
    Philip Burley
      @philipburley44197
      I could do with a bit of advice . I am building a simple crankshaft , at the moment it is a press fit together and in perfect alignment . I understand that silver solder wont penetrate through a tight fit , but I an reluctant to ease the pin and the shaft and maybe lose the alignment , What is others experience of Loctite and pinning ?
      regards
      #9142
      Philip Burley
        @philipburley44197
        #346948
        BOB BLACKSHAW 1
          @bobblackshaw1
          If you go to Tight running mill engine on the 06/03/2018, I had the same problem.
          #346950
          Philip Burley
            @philipburley44197
            your right , I didn't read all that post as I thought it only related to the out of line problem . Loctite and pin then !
            #346957
            Maurice Cox 1
              @mauricecox1
              If the Loctite is used correctly, you really don't need to pin it as well. It is very difficult to break a joint once it has cured. It takes far more force to move, even with heating, than the shaft will ever undergo when your engine is running.
              #346960
              mechman48
                @mechman48
                Posted by BOB BLACKSHAW on 21/03/2018 15:42:00:
                ​For those who missed it, The article is dated on 8/3/2018…
                George.
                #346961
                Mick B1
                  @mickb1
                  Posted by Maurice on 21/03/2018 17:02:40:
                  I think so, too – though presumably it depends on the forces.
                  I'd been thinking I'd pinned the crankshaft on the Stuart 10V I made about 20 years ago, but inspecting the crank now I can't see any sign of pinning, so I probably did just use red Loctite – and it still works well.
                  #346981
                  Mick Henshall
                    @mickhenshall99321
                    Anyone used Truloc 268 ( equivalent to Loctite 638 ) and have any thoughts about it, I'm about to use Truloc on my loco for wheels to axles
                    Mick
                    #347009
                      Pretty sure that's what I used to fit wheels on my wee loco.
                      Mick Henshall
                        @mickhenshall99321
                        Cheers Neil, I bought it from Arc so should be good
                        Mick
                        #347037
                        Thor 🇳🇴
                          @thor
                          Posted by Mick Henshall on 21/03/2018 19:08:21:
                          Mick
                          Hi Mick,
                          I have used Truloc from ARC to make a multi-throw crankshaft, as far as I can tell it is as good as Loctite.
                          Thor
                          #347065
                          mechman48
                            @mechman48
                            Thanks for the heads up on Truloc 268 guys, was looking to get equivalent to Loctite yes
                            George.
                            #347072
                              @mike89748
                              Yes to Truloc – just as good as the Loctite equivalents.
                              #347074
                              Mick Henshall
                                @mickhenshall99321
                                Thanks for the comments folks, I shall proceed with confidence whistling a happy tune
                                Mick
