Clayton Boiler Build
Home Forums Help and Assistance! (Offered or Wanted) Clayton Boiler Build
  • #33590
    David Watson 3
      @davidwatson3
      Sliver Slder
      David Watson 3
        @davidwatson3
        I am gathering a stock list to build the boiler for my Clayton. I only need 3/8 tube and foundation ring. That is normal stock from the likes of Blackgates or Mac Models.. The boiler came to me as a nearly full kit for the rest.
        The sliver solder is dependent on pricing, cup alloys. being favourite. I know its been a while since any one has built a Clayton boiler but can any one give me an idea how much they needed. I presume I would need to use two different silver solders to allow me to build he boiler in stages.
        #470941
        Phil P
          @philp
          I cannot remember exactly how much I used, but I only used one grade for mine, that was Easy Flo N°2 at the time.
          Not sure you can actually buy any of that these days though because it contains Cadmium, I am hanging on to my stock for a couple of future boilers I may or may not get rounf to building before I pop off.
          Phil
          #470952
          David Watson 3
            @davidwatson3
            Thanks Phil, I did wounder if I could get away with one grade of silver solder. Maybe a mid heat range. It would keep things simple. I am ok with silver soldering but havnt tackled a boiler before. The Clayton boiler looks easier than a loco boiler, thats one of reasons for building the Clayton.
            Apart from the Alex Farmer book on boiler building are there any other books on the subject worth reading.
