Hi Paul,
I can try and measure mine for you, i could either use a piece of string to measure the circumference or measure it straight length with tape and double up for the approximation. I'm not entirely sure what measurement is used for belts.
I also think it's 3 belts; 1 longer belt for the 3 higher speeds and 2 smaller ones for the lower speeds on the idler.
PS. (That is 3 for the lathe and 1 for the mill, i just realized sorry, mine is the cl430m, you will need to find someone else for you to get the cl500 mill measurement, unless it's the same as the other smaller ones)
I would be cautious using clarke service dept. I needed them before for 2 gears, to which they only sent me 1 and had to constantly call and check up on them for the next 6 months to get the remaining gear, they even denied that my order ever existed too, which i found a bit insulting. £62.70 is probably way over the odds for 3 rubberized mesh belts.
Since that occasion i've dropped the idea of using them like a hot stone. I'll do everything in my power to avoid relying on a third rate customer service dept.
Dont get me wrong, i really like clarke products but i can't say the same for the service dept, i think it's a case of giving the golden treatment to the big customers whose motors have broken down and giving the rough treatment to the guy who just wants a few bits and pieces.
Michael W
Edited By Michael Walters on 22/09/2016 14:39:17
