Church Redman Lathe Gears
Home › Forums › General Questions › Church Redman Lathe Gears
  • #22653
    ANTHONY DALE
      @anthonydale43434
      #121326
      ANTHONY DALE
        @anthonydale43434
        I'm missing a few gears from my Churchill Redman lathe and was wondering if anyone knew where i could get some spares ones or some that are compatable with another lathe?
        #121329
        Sub Mandrel
          @submandrel
          HI Anthony,
          Try poking around on THIS website. It may hold the answer, but even if not it will probably tell you much about your lathe.
          ANTHONY DALE
            @anthonydale43434
            Thanks, I have checked this already. Now looking at possibly making my own. Found some good info on the Internet. It looks straight forward enough. Any one else tried making gears?
            #121513
            Thor 🇳🇴
              @thor
              Hi Anthony,
              I have made extra change gears (module 1) for my Emco lathe. I used homemade cutters and a homemade dividing head. The process isn't difficult. Ivan Law's book: Gears and Gear Cutting explains both the theory behind gears and how to make gear cutters and gears.
              Thor
              Edited By Thor on 04/06/2013 14:03:33
              #121543
              ANTHONY DALE
                @anthonydale43434
                Thanks, I'll check that book out ASAP. Just wondering if most milling adapters for most lathes? Mine is rather old at 80 years!
                #121546
                Sub Mandrel
                  @submandrel
                  As Thor says, it's straight forward. I normally use the Ivan Law method to make cutters, but I filed a cutter for 1MOD gears by eye from gauge plate (see the latest MEW for details).
                  1 module cutter
                  #121561
                  Anonymous
                    Posted by ANTHONY DALE on 03/06/2013 22:52:57:
                    Making spur gears is simple, like this:
                    And a few more gears with the mandrels and gauges used to make them:
                    I've found that Ivan Law's book is great for spur gears, but falls down a bit on more advanced gears such as bevel and helical gears.
                    I expect you'll have no problem working out what the DP, or possibly Module, is of your existing gears, but the pressure angle may be a bit more of an issue. It may be 14.5°, or 20°, depending upon how 'stick in the mud' the manufacturers were.
                    #121606
                    RICHARD GREEN 2
                      @richardgreen2
                      Or like this,
                      #121708
                      Sub Mandrel
                        @submandrel
                        Gears cut using Ivan law method single-point cutters:
                        Cutting a large gear on X2 mill
                        Fordson Gearbox, right side
                        Two home-cut gears for Fordson Gearbox
