Chinese capstan mini-lathe
Home › Forums › Manual machine tools › Chinese capstan mini-lathe
  • This topic has 15 replies, 10 voices, and was last updated 4 May 2023 at 23:12 by Chris Pearson 1.
  • #643912
    Hopper
      @hopper
      Stumbled over this little snippet of video and thought it quite clever. The basic principles could be adapted to just about any lathe. I don;t know if you can buy it outside China but looks to have a built-in bar-feed collet set up and dead simple "capstan" arrangement for either/both cross slide and main carriage using nowt more than a disc of steel with offset pin and a bit of flat bar for a linkage.
      (Warning: Those of a sensitive nature regarding WHS should look away now or forever hold your peace.)
      Seems there have been several posts in recent months enquiring about capstan set-ups so this might provide some ideas.
      #14826
      Hopper
        @hopper
        Simple but effective
        #643919
        Hopper
          @hopper
          Could some kind passing mod please remove the extra "s" on the end of Chinese in the thread heading. I don't seem to be able to edit it out. Thanks.
          #643922
          Ady1
            @ady1
            Nice to see you back Hopper. Wondered how you were doing.
            #643927
              I wondered how they made those ARC 1-2-3 blocksdevil
              Not  a lot different to any second ops machine you would have seen in the past except they would have been running off a line shaft rather than individual motor
              Edited By JasonB on 04/05/2023 12:15:56
              #643930
              Hopper
                @hopper
                Posted by Ady1 on 04/05/2023 11:51:23:
                Thanks. Been living up to my name and hopping around on one foot after a bit of minor surgery. Glad I did not sign up for anything major.
                #643950
                ega
                  @ega
                  Posted by Hopper on 04/05/2023 12:21:52:…Been living up to my name and hopping around on one foot after a bit of minor surgery. Glad I did not sign up for anything major.
                  In North Norfolk, UK, the Hopper is the bus service that runs along the coast.
                  #643952
                  Ady1
                    @ady1
                    The cam gives you good leverage, feel, and accurate depthing
                    #643954
                    noel shelley
                      @noelshelley55608
                      EGA, Coast Hopper to be precise ! Are you on its route ? Noel.
                      #643957
                      Baz
                        @baz89810
                        Not strictly a capstan lathe as it has no capstan turret, just a work holding fixture, not much different to many second op machines seen in industry back in the sixties and seventies.
                        #643965
                        Clive Foster
                          @clivefoster55965
                          Hardly novel.
                          All the well known makers of precision bench lathes supplied the equipment needed for such lighter repetition and capstan duties. The well known Smart 7 Brown Model L is at the heavier end usually coming with a dedicated cast base but it's still fundamentally the same thing. Plenty more unheralded "industrial only" makers. SouthBend were one of the better known names offering similar accessories to convert lightweight bench, hobby and training lathes for such duties.
                          Not forgetting the morphologically different but effectively functionally similar small repetition lathes such as the "you're not getting paid until your arm falls off" Britan.
                          I guess it all got started around 1900 (ish) since then, until the Western de-industrialisation of the late 20th century, the number of parts made on such machines must be way beyond convenient, or even inconvenient, counting. Mostly for the complex, small mechanical devices largely superseded by "do you want it with chips" electronic revolution.
                          Hafta say I'm surprised that integrating Lego robotics to to the parts handling thing with a simple software programmed powered sequencer on machines of that style as an alternative to proper CNC hasn't become a thing. Basically think EMI-Mec lathe functionality but way cheaper. With a programming ap.
                          OK it's going to be slower than full on CNC. A Brother would probably blow its fuses laughing. But if you can hit at £5,000 (ish) a spindle plonk on a bench and its ready to go a bunch can produce serious numbers of parts for, probably, well less investment than a proper CNC. Even one running 24/7 could be cost effective for things its not worth setting up a proper CNC for half a day or so a week.
                          #643983
                          larry phelan 1
                            @larryphelan1
                            I think Clive might be right on the button there. The simple flypress can produce a vast range of stuff using simple tools and cheap and unskilled labour along with no power. Part of my mis-spent youth was lost in hanging out of one of those things, bashing out parts for heaters. Was impressed even then by the amount of bits it could produce, so these little machines might be something similar. Simple, cheap, effective.
                            #643985
                            Rainbows
                              @rainbows
                              Posted by Clive Foster on 04/05/2023 15:59:14:
                              Possibly along your idea. A three station capstan and cross slide all powered by steppers
                              #643993
                              Clive Foster
                                @clivefoster55965
                                Rainbows
                                Interesting video but very much a conventional type of CNC turret lathe made small.
                                Ultimately I can't see the price /performance / speed / size ratios working out for a viable industrial "use several small cheap spindles" machine.
                                Way I looked at it you'd use cheap mouse power steppers to set the stops and something more husky, but still inexpensive, like a DC motor to drive the capstan et al. The trick is being appropriately clever to keep the price down and afford automated materials and parts handling. Whole thing has to be very "ap dependant" to avoid needing skilled tool setters et al.
                                10 years back when I took a preliminary look at the concept for reasons that seemed valid at the time it was all do-able, although the human interfacing wasn't going to be nice, but would have been twice or more the maximum viable selling price. Now I'm comfortably retired so another career doesn't interest me. Nor does making one to prove I can do it.
                                #643998
                                ega
                                  @ega
                                  Posted by noel shelley on 04/05/2023 14:10:07:
                                  Sadly, no – just a lover of the big sky county.
                                  #644001
                                  Chris Pearson 1
                                    @chrispearson1
                                    Ah, a good old fashioned sweat shop!
