Hi Red, well only scary in that my main passengers will probably be both our great grand daughters (5 yrs & 6 yrs) and our local track is a raised one. Not only raised but some of it is on elevated banks so wouldnt want any accidents.
I,m quite happy with my design and I,m hoping that it should run well but I,m now wondering if I should add suspension to improve it further. I went back to my drawings earlier this evening and it wouldnt be that difficult to add spring mounted sliding axle boxes. As it is at the moment the axles are fixed and running in bearings mounted on the chassis side frames.
Will have to give it more thought and decide which way to go fixed or sprung.
Something else which threw me somewhat is the wheel back to back dimension, from GL5 specs I have drawn it up as 4.5/8" – 117.4 mm. I received 2 axles and 4 wheels today and the axles are giving a back to back of 119.2 mm. I,m now wondering if that is too wide but the supplier said it is all to GL5..?
cheers
Ron
