Chamfer Block
Chamfer Block
Home › Forums › Workshop Tools and Tooling › Chamfer Block
  • #492571
    Vic
      @vic
      I was only thinking the other day it would be nice to be able to put identical chamfers on all corners of an object.
      Sadly I don’t have either a surface grinder or a mag chuck but I may be able to come up with something for stuff I do have?!
      #19925
      Vic
        @vic
        #492575
        John Haine
          @johnhaine32865
          You can do it with a countersink used as a milling cutter, by accurate measurement. I'be done it by CNC but should be possible on a manual mill especially if you have DROs.
          #492581
          old mart
            @oldmart
            I do it by eye, but it is very difficult to get them identical.
            #492583
            jimmy b
              @jimmyb
              I spent a few weeks of my apprenticeship chamfering gear plates on a grinder that did just that!
              the plates were offered up from above. Quite boring and too easy to chamfer the edge that didn't doing!
              Jim
              #492601
              DC31k
                @dc31k
                1/4" woodworking router and a bearing-guided bit. Sleeve bearing OD to adjust width; use router's height adjustment for depth.
                #492611
                  I'm thinking a jig made out of a bit of angle iron with a slot cut in it, set across a grinding wheel so any metal slid along the vee gets ground down by the same amount.
                  Mike Poole
                    @mikepoole82104
                    Stefan Gotteswinter also felt the need and created this. **LINK**
                    #492638
                    Vic
                      @vic
                      Another method a little past half way of this video using a belt sander.
                      jimmy b
                        @jimmyb
                        This is a (very small) modern version of the machine I worked all those years ago.
                        This one uses milling cutters, not a grind stone, but the principle is easy to see.
                        Jim
                        Edited By jimmy b on 26/08/2020 05:11:13
                        #492657
                        colin brannigan
                          @colinbrannigan54160
                          Put the block in the vice, place a good quality countersink in the collet, my rear vice jaw is always set Y zero as is right hand side vice stop X zero, set the depth of cut and lock it, set Y to give required cut when happy make note of reading say +3 then go round each face adding 3 to each block dimension + or – and you end up with four chamfers all same size, turn block over repeat you now have eight. It may sound long winded but when you have a lot of tooling to chamfer you want them to look the same otherwise it's a pigs ear, same can be done with rads.
                          Colin
                          #492675
                          Clive Foster
                            @clivefoster55965
                            That Assflag machine in Jims link looks interesting but I think one of their other machines is more inspirational. The type AF165 **LINK** .
                            Take one of the cheap "disk on a motor" sanding devices, like the LiDL £30 one I got on a whim, and get creative with an adjustable angle mount rather than the fixed pedestal and it could do a variety of other jobs. Especially if you have alternative tables / holders. Lathe tools being the obvious one as a poor boys Tiplap. Which was the plan for my LiDL device. Drill sharpening and touching up milling cutters ought to be easy enough with appropriate cutter carriers. Bound to be something that can be modified and repurposed in the back numbers!
                            #492680
                            Hopper
                              @hopper
                              Cool gadget and a godsend if you are a commercial machine shop churning out lots of work with lots of edges to chamfer. But for my (admittedly snail's pace) output, a 10" flat millsaw file will do all the chamfers I need, with job held in the vice to allow a nice chamfer filed on one edge at a time. It takes more time but I have plenty of that these days.
                              #492687
                              Dusty
                                @dusty
                                Yes, what's wrong with a file? As an apprentice toolmaker I was taught to file chamfers on tools, you soon learnt to make them identical or incur the Foreman's wrath or worse still if it was a part for one of the toolmakers. 60 yrs on I can still file chamfers probably quicker than it takes to set a machine up to do them.
                                #492739
                                I.M. OUTAHERE
                                  @i-m-outahere
                                  Posted by Mike Poole on 25/08/2020 19:58:42:
                                  The original idea came from Robin renzetti i believe i and he recently uploaded a video showing his latest design .
                                  I personally like the way eccentric engineering did it on his acute sharpener video series( yes a plug for a long term advertiser on this forum) – a diamond lap or file . Gives very consistent results for small chamfers. Nice kit to build also !
                                  None of these do reviews as far as i know so should be ok here .
                                  #492749
                                  Clive Foster
                                    @clivefoster55965
                                    Realistically a power driven unit is a gadget too far for most of us but if its something else a tool you need for other duties can do then ….
                                    #494514
                                    Roger Best
                                      @rogerbest89007
                                      surprise I have a pneumatic thing I now need to dig out and have a close look at!
                                      #494525
                                      David George 1
                                        @davidgeorge1
                                        At the last place i worked at we had a pneumatic air grinder with a pair of adjustable blocks and you just run it round the block after adjusting the champher width with a thumb screw. There was a 2 inch grinding wheel on end of spindle behind the two Vee blocks. I believe you can get one with a cutter instead of grinding wheel but it made a lot of needle shaped swarf and can only cut soft steel.
                                        David
                                        #494527
                                        Martin Kyte
                                          @martinkyte99762
                                          I agree with Dusty, can't you lot use a file.
                                          I have put chamfers on in the mill but only because the block was in the mill at the time. The only other time was deep chamfers on the slots of the table of my tapping and staking tool.
                                          Oh and chamfers on trespar for tool stands which gets the router treatment.
                                          regards Martin
                                          ;O)
