Broken tap in copper boiler
Home › Forums › Help and Assistance! (Offered or Wanted) › Broken tap in copper boiler
  • #342350
    paul rushmer
      @paulrushmer83015
      Ideas please
      We have managed to break a 10ba tap in the back head of a new 31/2 gauge loco boiler, is this dissolvable with some acid ? I am shore this has been covered before but I can not find it on the forum. the tap is in a blind bronze bush which is proving very tough.
      Thanks Paul
      #33157
      paul rushmer
        @paulrushmer83015
        #342351
        Speedy Builder5
          @speedybuilder5
          Use this site – look for the keyword 'broken' alum seems to be the product you are looking for.
          BobH
          #342355
          Brian Wood
            @brianwood45127
            Brick or patio cleaner should do, they contain hydrochloric acid in sufficient strength so see that off. From builder's merchants everywhere
            #342359
            KWIL
              @kwil
              Alum will certainly do it. Build a little bund around the site with blue tack/plastacine and keep it topped up with liquid as the water evaporates. Not that fast but certain, keep poking the black residue to clear debris. Had the same problem with M3, just a little patience required.
              #342370
              Rik Shaw
                @rikshaw
                Having developed an allergy to deodorants I was recommended alum crystal stick which I have now been using for years. I do not have a problem with BO or BA ( bothersome axillaries ) and I am pleased to say my armpits have not dissolved (unlike my brain).
                Once you have removed your busted tap Paul I for one would be very interested how you got on – good luck!
                Rik
                #342390
                Tomfilery
                  @tomfilery
                  Paul,
                  I've recovered a brass part before (with a broken M2 tap in it) by leaving it overnight in citric acid. Tap turned rusty and basically dissolved. Suggest you try your usual brazing pickle.
                  Regards Tom
                  #342475
                  paul rushmer
                    @paulrushmer83015
                    Thanks all.
                    I have just bought some brick cleaner for removing mill scale as recommended by Jason and others, I will try that.
                    Paul
                    #342477
                    J Hancock
                      @jhancock95746
                      Will that stuff work on HSS taps ?
                      #342489
                        Posted by J Hancock on 20/02/2018 18:31:01:
                        Should do.
                        paul rushmer
                          @paulrushmer83015
                          Just to up date you all the Brocken tap came out yesterday as black mush, the long time is probably due to the size (10BA) very little room for the alum to flow round and clear debris and the fact it was left in the conservatory very cold this weather! Just got to modify fire hole door hinge to fit new bolt holes.
                          Thanks again Paul
                          #346672
                          Jim Nic
                            @jimnic
                            Thanks for the good news update.
                            Jim
                            #346680
                            Richard S2
                              @richards2
                              Glad you've succeeded in it's removal. I have just this week removed a piece of broken 10ba Tap from a through hole in 1/8" of copper on my boiler. Took 4 days using sulphuric acid (ex car battery 30 years ago), probably quicker, but I could only use very little at a time in a small 'bunded' area. Very pleased also with the results of the process.
