brass wire mesh in 1mm weave
Home › Forums › Beginners questions › brass wire mesh in 1mm weave
  • #67555
    Clive Hartland
      @clivehartland94829
      I have a requirement to make some new baskets for our Ultrasonic tank.
      The old ones have now worn away on the bases with the activity.
      I have been searching on the net and some of the prices for a Sq Mtr of brass mesh are frightening. One was £201 pre Sq Mtr, one I found at £48 per.
      Does anyone know of a better source that can supply smaller pieces?
      I have tried all the normal traders like Reeves and Arc Euro and Chronos.
      #5491
      Clive Hartland
        @clivehartland94829
        #67556
        Rob Stevens
          @robstevens54297
          Try the following:
          I have not purchased from them but looks useful.
          Rob
          #67557
            Blackgates do a brass starining gauze but its more like 0.5mm if thats any help.
            Blackgates and Bruce both do stainless mesh as well.
            Jason
            #67558
            David Clark 13
              @davidclark13
              Hi Clive
              Could you repair some of the bases by using the sides of one of the others?
              Just to get you going again?
              regards David
              #67559
              Dusty
                @dusty
                Hi Clive
                Try Squires Tools Bogonor Regis. It’s the sort of thing they stock.
                #67560
                MichaelR
                  @michaelr
                  Try this site Here, you can get a instant quotation by typing in you requirements they have all types of mesh.
                  Stick.
                  #67566
                  Clive Hartland
                    @clivehartland94829
                    Hi David, In fact we are down to the last basket and the more use it gets the worse it gets!
                    Thank you for all the info I am now going through them to see which is the best quote.
                    I still have the dolly former from all those years ago when I first made them so I can get to it straight away.
                    Out of interest, when we went from Freon and Chlorothene in the tanks I had to find a substitute medium.
                    Eventually came across an aqueous solution called Micro. This is used in a 2% solution and is very economic and biodegradable.
                    It is used by the US Nuclear industry to clean components and in tests out performed Freon for surface detritus.
                    #67633
                    Clive Farrar
                      @clivefarrar90441
                      Clive,
                      how much are you looking for ? At work we have some that is about 30 threads per inch.
                      We used to uase it for clay seiving before we “perfected” other methods of cleaning the clay.
                      It is about 2′ wide and I could probably aquire 1- 2 ‘ for you.
                      Alternatively when I used to work in an automotive paint shop we used a synthetic material
                      “nytal seiving ” to repair the powder coat vibro seive. This was available in a great many weaves and thicknesses.
                      Google that and i found the following
                      meshdirect.co.uk
                      Stanair& co manchester
                      Russell Finex Ltd. – Based in the UK
                      Spares and aftermarket service direct contact numbers are:
                      Phone : +44 (0)20 8818 2020
                      Fax : +44 (0)20 8818 2021
                      Email : [email protected]
                      is that of any help to you.
                      Regards clive
                      #67635
                      Clive Hartland
                        @clivehartland94829
                        Clive, Nice to meet you here!
                        The baskets are about 5″ dia and about 4″ deep to fit the ultrasonic tank. The suspension basket will take two that size and there are four of us who use it.So roughly 5″ x 16″ plus 4 bases 5″ x 4 at the width you quote, 24″llength would do it, the sieve size is not really important as it will be less than a 1mm mesh.
                        As the ultrasonic runs at about 60C. I am dubious about synthetic materiel? and its longivity under the action of the ultrasonic vibrations.
                        would appreciate any help on this to keep cost down.
                        I can do a trade with you if you have any ‘ wants’. I have a couple of Dti’s not being used.
                        You can contact me on the, ‘My message’ system.
                        Regards Clive
                        #67654
                        Ian S C
                          @iansc
                          If your into stripping old microwave ovens, some of them use stainless mesh in the door, others have perferated steel sheet metal. If it looks as though it might have something useful I pull it to bits, been doing it since I was 6 or 7 years old. Ian S C
                          #67660
                          V8Eng
                            @v8eng
                            Two more possible suppliers to look at.
                            Edited By V8Eng on 28/04/2011 19:02:09
                            #67661
                            Clive Hartland
                              @clivehartland94829
                              Thank you for all pointers to wire mesh, I have looked at them all.
                              #67676
                              Ian S C
                                @iansc
                                I called in at the local second hand shop this morning, and there for just a few dollars, a fire screen made of wire mesh, just about the right size, just a wee bit far away, but that may be a place to look all the same1 Ian S C
                                #75155
                                Daniel Austin 3
                                  @danielaustin3
                                  If you’re still after some, you might be able to find something here:
                                  #75165
                                  Terryd
                                    @terryd72465
                                    Hi Clive,
                                    When I needed some of this stuff I bought some frying pan splatter guards, They are just flat circles of stainless mesh about the size you need. they are about 350 mm dia and cost around £1.99p in a local general store.
                                    You would need to bastardise several but at that price?
                                    Terry
                                    #75166
                                    Clive Hartland
                                      @clivehartland94829
                                      Thank you lads, I should have posted earlier.
                                      One of our forum members was able to get me some mesh which I traded him with some Honey.
                                      I managed to make 8 baskets in all with what he supplied.
                                      Going back to the original problem with the baskets we had, the ultrasonic tank of course vibrates and in doing so wears away the base ring of the mesh basket and after some time the bottom drops out.
                                      #75183
                                      pcb1962
                                        @pcb1962
                                        Posted by Clive Hartland on 19/09/2011 22:16:08:
                                        Could the baskets not be suspended in the tank to prevent this?
