Boring Head
Boring Head
Home › Forums › Workshop Tools and Tooling › Boring Head
  • #354326
    Alan Gordon 4
      @alangordon4
      Hi Guys, I have scrapped a small crank case due to the bored hole being off centre !!
      I have started a new crankcase and ensured that all was centred and locked down, I installed a new Vertex boring head and a new cutter and turned the head by hand very slowly, I was amazed to see that when the cutter was set to just graze the inside surface of the pre drilled hole but when turned 180 Degrees it wanted to over cut ? This why the first hole was off centre. I am sure I am doing something daft but I cannot figure this out. Any help would be appreciated.
      Alan
      #18930
      Alan Gordon 4
        @alangordon4
        #354336
        JohnF
          @johnf59703
          Alan, where did you zero your spindle centre ? did you clock the inside of the crank case or did you clock the drilled hole ? On first thoughts it seems to me you zeroed the spindle to the inside of the crank case and the drill hole is already off centre ??
          A photo or drawing of the job may well help.
          I have PM you as well John
          #354348
            Wandering drill?
            #354350
            Andy Carruthers
              @andycarruthers33275
              Is table locked too?
              #354351
              fishy-steve
                @fishy-steve
                Have you trammed the head?
                #354352
                chris stephens
                  @chrisstephens63393
                  Second for tramming your head, the boring head is probably longer than the drill so will be more to one side.
                  #354353
                  not done it yet
                    @notdoneityet
                    Assuming here the boring head has been changed on the same machine/workpiece setting?
                    Changed head height on a round column machine? Relying on a drilled hole to be straight?
                    If not, you could try removing the boring head and installing it at 180 degrees in the machine and look for a different result. Possibly there is something (foreign body or a burr) inside your spindle that needs cleaning out?
                    Possible tramming error and one side is off centre when drilled?
                    If I want to drill something true, I use an end mill, not a drill.
                    Several possibilities so, yes, a pic and detailed method of working is likely required to see what is wrong.
                    #354355
                    Alan Gordon 4
                      @alangordon4
                      Thanks guys for your advice, I have taken all advice and I believe the problem was backlash. I ensured that I took out as much backlash as possible on X and Y axis and kept checking my DRO to ensure that 0.000 was always showing with no drift. Mission acomplished.
