boiler reg h.s.e
boiler reg h.s.e
Home › Forums › Beginners questions › boiler reg h.s.e
  • #42064
    david simmo
      @davidsimmo
       hi can anyone tell me were to get the reg concerning m.e. boilers (new regs ) and will it afect old design looked on internet not much good on compter
       thanks dave
      #4702
      david simmo
        @davidsimmo
        #42162
        Nigel Hyde
          @nigelhyde97004
          Hi I have just noticed your post
          I am a member of (GEC) coventry mes and we are a member of the midland fed and southern fed (I think) and our boiler inspector issued us with the new regulations i think they cost about 30p ! so if you get in touch with your local fed they may be able to help
          I am no expert on boilers and the regs!
          just completing a 3.5″ tich boiler!
          hope this helps
          #42339
          Norman Barber
            @normanbarber28134
            Hello David,
            If you type in THE EXAMINATION & TESTING OF MINIATURE STEAM BOILERS in your search engine (Google?) you will obtain a copy of the lates edition of the British code.
            #42436
            Albert
              @albert
              Hello,
                 Send a e-mail to Tony Wood at Walker Midgley–he will send you the regs
              [email protected]   He insures a lot of T/Engines and most other items in model engineering
                 Albert
              Edited By Albert on 19/07/2009 16:20:52
              #42461
              V8Eng
                @v8eng
                Hello.
                I got a useful little booklet at the last ME Exh, it is published by the Federations.
                Lots of useful info in the publications section of their web sites.
                #94552
                Joseph Ramon
                  @josephramon28170
                  I see from the Walker Midgely site that boilers of less than 3 bar-litres capacity don't need a test certificate **LINK**. I estimate the capacity of the large Tich boiler as about 450cc, and the pressure is no more than 90psi (max, so that's roughy 0.450 x 4 = 1.8 bar litres.
                  Froma purely legal insurance perspective, not individual club requirements, is it therefore correct that a Tich boiler would not need a test certificate?
                  Joey
                  #94553
                  Anonymous
                    Errrrr, where did the '4' come from; I make 90psi more like 6.2 bar?
                    #94564
                    Sub Mandrel
                      @submandrel
                      Interesting. Still comes to less than 3 bar litres, if the volume is worked out right.. Is 90 bar a bit highor Tich?
                      Are there 2 or 3 boiler designs for Tich? I thought there was a 3" large boiler and a smaller 2 5/8" boiler with a belpaire boiler. But it appears the belpaire may be the nbest of them all. is there a 'standard' small boiler?
                      I'm going to post some Tich observations in another thread.
