Boiler maker identification
Home › Forums › Locomotives › Boiler maker identification
Viewing 15 posts - 1 through 15 (of 15 total)
  • #438100
    Manofkent
      @manofkent
      I have just bought a part built model of LBSC's "Miss ten to eight".
      It came with a beautifully made boiler.
      The boiler is stamped "RC 332".
      I am guessing it was professionally made. Just out of curiosity does anyone know who the maker was?
      Many thanks
      Manofkent
        @manofkent
        #438110
        Robert Newman 2
          @robertnewman2
          Probably Reg Chambers
          #438119
          Baz
            @baz89810
            Agree with Robert, Reg Chambers of Weymouth.
            #438127
            Former Member
              @formermember19781
              #438207
              Manofkent
                @manofkent
                Thanks all.
                I have heard of Reg Chambers' boilers and the high reputation he had.
                Sounds like I have picked up a bargain here, and my boiler inspector should be pleased!
                Excellent and knowledgeable forum. Thanks again.
                #441295
                Nigel Graham 2
                  @nigelgraham2
                  Tra-la!
                  I own what I understand is the last boiler that Reg Chambers built – oh, and the locomotive wrapped around it.
                  Its Boiler Test Record gives its Identity Number as RC180, built in 2000.
                  180. Yours is RC 332.
                  Oh! Ummm….
                  Perhaps the number is not a straightforward serial number. In any case, although Reg made boilers professionally for many years, over 300 seems a lot given that he was probably among the first in that trade.
                  If the number genuinely is a serial, starting at Boiler Number 001, I would be wondering when he made my boiler (I bought the loco a few years ago, after the Club replaced it by another); and does it mean he had a boiler for an LBSC 'Juliet' X 2-size, sitting unused in his workshop while he built another 150+? It was definitely unused when we fitted it to the locomotive in 2000; and although I don't know when Reg passed away I don't think it was long after that.
                  On the other hand, I would be very surprised if Reg ever built 1000+ boilers as 34046 had heard.
                  So I believe your boiler is by Reg Chambers, but probably not the three-hundred-and-thirty-second. This all suggests he had an ID system of his own that he has taken with him – and a bit less than 20 years ago.
                  Incidentally, the BTR also shows mine as built non-commercially, because Reg built it as a favour for his own society, which 34046 identifies, Weymouth & District MES.
                  #547606
                  Geoffrey Wright
                    @geoffreywright91241
                    Hello Nigel,
                    I'm just looking for info on my Reg Chambers boiler and came across your post here. My Springbok boiler has the number RC766 on the backhead, lower right, but no date. It's a strange build for a Springbok (B1) as it has boiler feed clack bushes at the smokebox end! I've blanked these off, but wonder why someone would have a B1 boiler built with these fittings. I'll never know, LOL!
                    Geoff
                    #547988
                    Nigel Graham 2
                      @nigelgraham2
                      I can't comment on the feed arrangements on the Springbok, but I asked on one of my club's boiler inspectors if he had encountered Reg Chambers' number system.
                      He has tested one Chambers boiler, but did not know how Reg's system worked so suggested either month or serial-number and year, with the serial being annual rather than continual.
                      So 766 may mean "July 1966", but it fails with others quoted here.
                      332 = March 1932? I don't think so. Nor indeed my 180 supposedly = August 2000, on the last boiler he made. That is questioned by the digit 1, and proven incorrect by RC180's blue card dating its Initial Hydraulic Test to 28 March 2000. Not August.
                      So does 766 mean the 7th made in 1966? Feasibly, until you ask if he really built 18 boilers within the first 3 months of 2000. If I recall aright he had already retired from boiler-making but built RC180 as a favour to his own club.
                      I am sure Reg's system was logical in its own way, but the more we try to analyse it the more it seems we need that strange round "calculator" that foxed us all here some months back!
                      Reg was a member of my own society, but there are now only two, possibly three, others who were contemporaries of Reg so might have known his number system. One is me and I don't. I doubt the other one or two would either.
                      #548401
                      Geoffrey Wright
                        Hi Nigel,
                        From a question I posted on the FB 5 Inch Gauge site, from the responses it appears that my boiler is (could be?) 1986 or 1987. One member of the site had a boiler number RC713 built in 1986. Another had a boiler from Jan 1988 numbered RC801. Looks like there could have been some logic in the numbering system at that time.
                        Thanks for your reply.
                        Geoff
                        #549870
                        Martyn Myer
                          @martynmyer81895
                          I have owned but subsequently sold a 3 1/2 inch gauge Britannia which had a Reg Chambers made boiler serial nuber RC355 which the paperwork clearly shows was delivered ito the purchaser n April 1972.
                          so clearly Reg had a serial numbering system which had some logic to it that we as yet can't fathom
                          the following is from some notes i prepared for a nomograph on my 3 1/2 inch gauge Pacific collection:
                          "When stripped down a boiler builder’s code “RC355” was discovered at the base of the
                          backhead. Certainly the original workmanship seemed to indicate a professional builder. Some querying
                          of dealers in the UK and a subsequent web search revealed that the boiler was built by a Reg Chambers
                          of Model Steam Boiler Specialists in Weymouth. He delivered the boiler to his customer a W. J.
                          Robinson of Wimborne Minster in Dorset on 13th April 1972 for a price of £57.00 (approximately £500.00
                          in 2005 &pound. The boiler was silver soldered throughout, pressure tested to 160 lb/sq in. and given an
                          insurance industry test certificate number 158. Reg took care to see that no surplus solder was left inside
                          the boiler especially around the firebox.
                          Born in 1931, Reg has lived in the UK all his life apart from 3 years in the late sixties when he and
                          his wife lived in Australia. Reg was a very well regarded professional boiler builder who indicates he was
                          the first builder to put their “signature” and a serial no. on their boilers to enable tracing the records and
                          provenance of individual boilers. This proved correct when I called Reg in September 2007, he was able
                          to put his finger on all this information in the course of the brief phone call. Reg’s personal interest was in
                          traction engines and he built several, the last of which is to go to his daughter. When he retired from
                          professional boiler making in 1990 he was charging £400-500 for a new boiler."
                          in hindsight i should have asked him about his numbering system when i talked to him 14 years ago. My guess is that Reg has unfrotunately passed away.
                          #549883
                          Colin Heseltine
                            @colinheseltine48622
                            I have a part built 1" Minnie traction engine which has passed through several owners before reaching me.
                            This also has a boiler apparently made by Reg. The serial number on mine is RC335.
                            It would be nice to put a date to when it was built.
                            Colin
                            #549889
                            Former Member
                              @formermember12892
                              #549898
                              Colin Heseltine
                                Bill,
                                Thanks for that info. I'll add it to my notes
                                Colin
                                #549971
                                Nigel Graham 2
                                  @nigelgraham2
                                  I have just sent a message to the one person still about who might know Reg's number system… knowing he probably won't, or will have forgotten.
                                Home › Forums › Locomotives › Topics
