Battery connection
Battery connection
Home › Forums › Locomotives › Battery connection
  • #1365
    Matthew Worthington
      @matthewworthington53937
      #177039
      Matthew Worthington
        Hi all,
        I'm new to this and would appreciate some help on how to connect a battery on a 5" gauge locomotive. The photo (see link) shows the connection to the motor/controller on the left and the battery (and its terminals) on the right. Can anyone please advise what type of connection/wire I need for this? Many thanks in advance
        **LINK** – link to photo.
        Matt
        #177045
          Welcome, Matthew
          Those connectors were originally known as 'Lucar' [Trade Name] but are more commonly just Spade Terminals.
          … Any automotive parts supplier should have them in stock.
          http://www.google.co.uk/search?q=lucar+connectors
          Edited By Michael Gilligan on 23/01/2015 20:45:51
          #177048
          Johnboy25
            @johnboy25
            Matthew…
            i belive the connectors are Anderson type connector. Try **LINK**
            If do a search on eBay for Anderson connectors I think you will find what you want. The battery connections are as Michael has indicated. The other name for them are Spade connectors or Fast on.
            Bob Brown 1
              @bobbrown1
              As a point of interest what size is your battery and motor/s, I ask as my electric shunter runs a pair of 38amp hour batteries with bolt on connectors supplying 3 x 150 watt motors. I worked on the current the motors were likely to pull say 12 amps ish so the batteries should give a two/three hours of running or may be a bit more with regen braking.
              I would use normal spade connectors to connect that battery and fit a isolating switch so the batteries can be isolated easily should a problem arise.
              Bob
              #177059
                Posted by Johnboy25 on 23/01/2015 21:14:06:
                Matthew…
                Thanks for the extra info., John
                I was, of course, only referring to the battery connection.
                Matthew Worthington
                  Many thanks for your help folks
                  #177772
                  MichaelR
                    @michaelr
                    Look like Power Pole connectors see Here
                  Home › Forums › Locomotives › Topics
