Baker valve gear
Baker valve gear
Home › Forums › Locomotives › Baker valve gear
  • #480148
    Mikelkie
      @mikelkie
      I am currently building a freelance loco in 7 1/4 in, and found some conflicting "statements" in LBSC'S Shop shed and road describing Baker valve gear for locomotives, Page 100, 101 in where it says that the the valve spindle goes on the top hole of the combination lever for outside admission (slide valve) and below for inside admission (piston valve). However in the book from the Pilloid Co it s the opposite. did any builders used Baker valve gear and came across this problem, or am i off course or missed something?
      Edited By Mikelkie on 16/06/2020 09:15:39
      Edited By Mikelkie on 16/06/2020 09:18:07
      #1944
      Mikelkie
        @mikelkie
        #480169
        Simon Collier
          @simoncollier74340
          I just checked SR & S. That has got to be a typo or similar. Follow your other reference.
          #483385
          David Reeves 1
            @davidreeves1
            I suggest that you download the late Charles Dockstader's valve gear simulation software from
            **LINK**. The software is old but will run on a PC although you may need to run it in compatibility mode for Windows XP.
            Then run the files for Baker inside admission and then Baker outside admission: Bake_IN.exe and Bake_OUT.exe respectively. These show the same arrangement as you have seen in LBSC’s book i.e. Baker outside admission has the valve spindle connected to the top of the combination lever with the valve rod below it. These positions are reversed for inside admission piston valves. The software allows you to see the effects of altering the dimensions of the components and obtain graphical results.
            #483568
            Mikelkie
              @mikelkie
              Hi David thank you for your response, I will do so and thanks for the link. Regards Mike
            Home › Forums › Locomotives › Topics
