Any idea what this is?
Home › Forums › Beginners questions › Any idea what this is?
Viewing 25 posts - 1 through 25 (of 25 total)
  • #9167
    Steven Anderson
      @stevenanderson90224
      #351280
      Steven Anderson
        Hi everyone. I am absolutely new to model engines, so couldn't tell you anything about what I am looking at. I am replacing the kitchen in the house and as i was tearing out the old units I found something interesting hiding behind it all…
        As far as I can tell, none of the parts have ever been out of the plastic wrap, although air has been getting in and there is rust present on some parts. There is a red sticker on the back of the box which says "Stuart Sun Engine Machined, Made in England"
        Is it of any value, or will i start tearing the parts out, cleaning them and putting it together? I'm a marine engineer so i have some degree of confidence in putting this together, although instructions or a helping hand would be much appreciated!
        #351295
        nigel jones 5
          @nigeljones5
          Its a Seuart Turner Sun Engine (castings), bit of a find as they no longer sell this line.
          #351297
          Steven Anderson
            thank you 😀 What do you mean by castings? I notice on the Stuart website there is "castings" (unmachined) and machined kits.. whats the difference? Is this worth much? I'm itching to break into it but If its of any value Id rather someone who genuinely wants this would have the honor.
            #351298
              The Sun was one of their range of high speed enclosed marine engines intended for use in a boat most likely powered by a flash steam boiler. They could also be used to run a dynamo or small pump. Bit of the history of these engines here
              The machined kit which you have would have cost 3-4 times that of the raw casting set so if they made it today you would be looking in the region of £1000. If you do sell it you will get more with the packaging intact
              J
              Edited By JasonB on 23/04/2018 18:40:08
              #351302
              Ian Parkin
                @ianparkin39383
                Some previous owner of the house hiding away purchases from the boss?
                #351304
                Mick B1
                  @mickb1
                  It won't be just a matter of putting it together – the raw castings will have to be machined to the correct dimensions. If there's no drawing set with the castings, any purchaser will need to find one, or work out suitable dimensions themselves – possible, potentially with difficulty.
                  Edited By Mick B1 on 23/04/2018 19:13:38
                  #351307
                    It's the set of MACHINED castings so just assembly and a bit of fettling required. The Sun was available in 3 formats – castings, machined and assembled.
                    #351309
                    Steven Anderson
                      Interesting read JasonB, thank you. So, is my set machined or cast? The set I have looks to be machined and ready to go together, but I'm no expert! I'll take it to the local model engine guru on Friday as he's away just now and I'll let him have a proper look but I won't be opening up the packaging! Most likely Ian… Its the only explanation I can come up with!
                      I'll post an album with some close up photos. There is rust present on parts but none of it is terminal as far as I can see. I've certainly repaired worse (On much, much larger engines mind you)
                      No paperwork Mick, everything is in the photo.
                      #351310
                        Definately the machined set of parts, you can see the holes in things like the end covers both reamed for the crank and the smaller ones on a PCD to fix them to the crankcase, crank is also machined.
                        #351312
                        mechman48
                          @mechman48
                          Do the pieces look finished machined; i.e. crankshaft journals finished to size, do the cylinder bores look as though they're finish bored etc. etc. as a marine engineer you should be able to tell when a piece has been finish machined or otherwise. Looking at the pic it seems as though the cylinder covers, crankcase & base need further work, have the pistons been machined, if not then it is a set of castings to be machined up otherwise it is a 'kit' that can be assembled ready to run. Looking at the packaging I would suspect it's a set of castings.
                          George.
                          #351313
                            Found you a set of drawings here and looks like I was about right with the machined kit being 3-4 times the cost though a bit cheaper than the £1000 it would cost today if still made
                            #351316
                            Steven Anderson
                              It is machined, I can absolutely confirm that. Pics to follow. its difficult for me to tell because the plastic is quite dirty and my experience with these engines is zilch! I thought It was machined until people here said otherwise and you're right about the crank. At least, I'm used with crankshafts having a bit more.. weight to them! haha. Uploading pics to an imgur album, will share the link.
                              #351317
                                This is what the crank would be like if you had the raw casting set
                                #351318
                                  Near bottom left is the little packet of fixings.
                                  Lovely find.
                                  May be a challenge to assemble correctly with bevel drive to the valve. The strip material is cylinder cladding.
                                  Not sure it's fully machined. No exhaust or mounting holes, looks like just the tricky bits are done, but not the simpler drill and tap bits?
                                  Edited By Neil Wyatt on 23/04/2018 19:54:38
                                  #351319
                                  Douglas Johnston
                                    @douglasjohnston98463
                                    £2-3s-6d, oh happy days! Mind you I wonder what the average wage was at that time. If only we could have those prices along with todays wages. One can but dream.
                                    Doug
                                    #351320
                                    Steven Anderson
                                      https://imgur.com/a/2HxAA1E
                                      Link to album with a close up of parts.
                                      Edited By JasonB on 23/04/2018 20:08:35
                                      #351321
                                        Posted by Neil Wyatt on 23/04/2018 19:52:23:
                                        Blow i up large enough and the holes are there just hard to see through the old plastic.
                                        #351322
                                          The small stepped bush next to the wrist pins goes into the "banjo" and takes the eccentric pin from the vertical shaft.
                                          Neil has answered what the strip a "blued" steel is for.
                                          There are not many parts to this engine and the sectioned assembly on the drawing I linked to will show where all the bits go and it shows the timing arrangement too.
                                          Edited By JasonB on 23/04/2018 20:11:45
                                          #351331
                                          Steven Anderson
                                            Well, a massive thank you to everyone for all your input. It seems I have a relatively valuable piece of kit here?? I will be keeping a hold of it for now. perhaps within a week or so when "an expert" has seen this in the flesh and can give me a ballpark value figure, I'll chuck it up on Ebay. If there's a better place to be selling this I'll gladly post there too. Naturally though this has spurned on my interest in these things, can anyone recommend a kit in the region of 200-300 that's half decent?
                                            #351347
                                            Old School
                                              @oldschool
                                              I have just finished a Sun engine machined from castings it makes a nice engine and it ran first time on air.
                                              #351355
                                              Hopper
                                                @hopper
                                                Posted by Ian Parkin on 23/04/2018 18:57:37:
                                                In the kitchen of all places? Hardly seems likely. I'm sure there's a fascinating story behind it somewhere though. Boss hiding a secret Christmas present that never got to be given? We'll never know. But a fascinating find for sure.
                                                #351374
                                                Ian Parkin
                                                  @ianparkin39383
                                                  If I wanted to hide something from the boss that would be the best place she never lingers round the kitchen ! its fully my domain
                                                  #351379
                                                  Jon Gibbs
                                                    @jongibbs59756
                                                    Jammy so-an-so.
                                                    I particularly liked the coincidence of a marine engineer finding a model marine engine in bits.
                                                    Frankie and Benjy mouse must have spent some time on that one!
                                                    Edited By Jon Gibbs on 24/04/2018 08:52:03
                                                    #351384
                                                    Former Member
                                                      @formermember19781
