The project I've slowly been working towards is to build a wood lathe.
I've got some 40mm bar for the spindle and 4 bits of 150mmx150mmx20mm to make the headstock from.
Basically, the idea is to square up the 4 bits, make a box and bore a hole for the bearings.
In hindsight, I've realised that my mill has a Y travel of 4 inches and the steel is 6 inches wide.
I've tried to surface it with a flycutter, but that stopped when it broke my mill (plastic gears). When I looked at the flycutter it appeared that I'd managed to wear the cutter flat fairly quickly – without much impact on the steel, and it may have been the pressure trying to get the damned thing to cut rather than the actual cutting of the steel that laid it low. Still, I'm rather nervous of trying this again (though I do have a handy stock of gears, now).
My second thought was to mill a channel on each of the four edges about an inch wide and 2 mm or so deep – do that on both sides. Then mill the centre part flat and parallel on both sides (taking off 1mm). Finally recut the channels with the centre area providing the registration.
In theory this should work with all the surfaces ending up parallel, but it's a lot of mucking about and clearly getting round a problem to which the solution is a bigger mill or a rethink. Or perhaps building a small traction engine instead…
I may have another go at the flycutting, but I had thought the contour of the tool was reasonable given the various (conflicting!) recommendations on the interweb.
The plates are from metal bits and mild steel, though I don't have a specific specification.
They are black and I wonder if taking off the surface with a sanding belt would help my case.
Sorry, this is a bit long, but I didn't really want to start a tedious process if there was a way round it!
Iain
