I picked up a nice little Eclipse #220 pocket scribe yesterday, for no money (OK, I paid 20p).
The reversible point was (as usual) stuck, but the usual combination of lubricant, cleaning, and careful application of force got it out easily enough.
Sadly, it was snapped.
Checking my other 220's (it turns out I already had 2), I discovered that the newer models have a 1/8" (0.125" ) scribe, while the latest acquisition (which I judge to be the oldest of them, it's more nicely made), had a 1/10 (0.100" ).
Tricky. Where does one get 1/10" stock?
Re-checking (with a vernier'd micrometer, not a dial caliper) showed that the 1/8" point was very accurate indeed; 0.1248", only two-tenths off. Wow, Eclipse make accurate stuff!
The 1/10" was not so good, a coupla' thou short, 0.098".
Not very accurate. Hmm.
Acting on hunch…
0.098" in mm is 2.489.
Re-checking the micrometer, the actual reading is more like 0.0985", which is 2.502 mm.
It's METRIC (and bang on accurate, too). I should have trusted Eclipse all along…
BugBear
Edited By bugbear6502 on 03/09/2018 11:16:16
